Author Topic: PROBLEM :New Tutorial : PWM on ATmega168  (Read 1943 times)
Offline zverukasTopic starter
« on: October 12, 2010, 12:41:45 PM »
Hi, i can't compile it on gcc.
I always receive an error: "../pwm.c:250:23: error: "*" may not appear in macro parameter list"
on lines :
#define pwmSet9(ICR1 * val /255)   OCR1A=val
#define pwmSet10(ICR1 * val /255)   OCR1B=val
also warnings : "../pwm.c:135: warning: implicit declaration of function 'sbi'"
on :
void pwmOn9(void) {
   /* Pin 9 on*/
//9 A on - set at Bottom, clear at compare match
   sbi(TCCR1A,7);
  cbi(TCCR1A,6);
any ideas ? :-\
  • Helpful? 107
Re: PROBLEM :New Tutorial : PWM on ATmega168
« Reply #1 on: October 12, 2010, 12:51:54 PM »
on lines :
Yep - not surprised - that #define is full of errors. The original author of that tutorial was airman00. Hopefully you will get a response from him and he will fix the tutorial.
on :
void pwmOn9(void) {
   /* Pin 9 on*/
   sbi(TCCR1A,7);
  cbi(TCCR1A,6);
any ideas ? :-\
The cbi and sbi marcros aren't defined
Try placing this at the top of your program-
#ifndef cbi
    #define cbi(reg,bit)    reg &= ~(BV(bit))
#endif
#ifndef sbi
    #define sbi(reg,bit)    reg |= (BV(bit))
#endif
« Reply #2 on: October 12, 2010, 01:46:25 PM »
hmm ::)
../pwm.c:142: warning: implicit declaration of function 'BV'
Offline KurtEck
  • Helpful? 12
« Reply #3 on: October 12, 2010, 01:54:43 PM »
My quick guess at this is BV is probably defined something like:
#define BV(bit) (1<<bit)
You can probably put this in an #ifndef like the other ones...
Kurt
Last post January 20, 2008, 09:46:40 AM
by rox2007
Last post July 04, 2008, 03:49:06 PM
Last post December 02, 2008, 01:58:27 AM
Last post January 29, 2009, 10:50:20 PM
by Webbot
