2
Author Topic: solenoids for jumping robot  (Read 2746 times)
Offline roboSonnyTopic starter
« on: October 13, 2010, 02:46:53 AM »
what type will be more effective a push solenoid that pushes plunger or a pull when the plunger is released and uses the spring?
Re: solenoids for jumping robot
« Reply #1 on: October 13, 2010, 02:23:24 PM »
The push type will be stronger.
Offline futurrobotech
« Reply #2 on: October 14, 2010, 08:01:04 PM »
also i saw somebody using solenoids to jump on tv or something one time and just using one they had the robot getting like 60 feet in the air
« Reply #3 on: October 15, 2010, 05:24:01 AM »
i understand that the push type will be stronger but for a jump i will need abrupt release of energy that  i think i will get from a pull type.what do you think?
Offline Gualalasmooth
« Reply #4 on: October 15, 2010, 12:14:24 PM »
How big is your jumping robot  ?
« Reply #5 on: October 15, 2010, 04:07:17 PM »
I think you shouldn't waste peoples time asking questions if you already made up your mind!
It's simple math. The more power the better (up to a limit of course).
The spring return is much weaker, as the solenoid need the power to do its work AND the power to overcome the spring return at the same time.
That's how it is, but do whatever you feel like.
