Author Topic: Help with Webbot Project Designer  (Read 851 times)
Offline thornsb1Topic starter
« on: October 14, 2010, 11:13:28 AM »
I cannot get the Project Designer to open. I suspect that there is a problem with Java. I have reinstalled everything but it still wont open. Does anyone have suggestions? I am running Windows 7 64-Bit.
Offline madsci1016
  • Helpful? 43
Re: Help with Webbot Project Designer
« Reply #1 on: October 14, 2010, 11:22:39 AM »
What are the symptoms?
I also have Win 7 64bit, and i get an error 25-50% of the time. I just run the installer again (here), and it then opens fine.
« Reply #2 on: October 14, 2010, 11:31:02 AM »
Thx. I tried the link you posted but it does the same thing. A terminal screen opens only for a moment and then disappears. I never had this problem before. I just dont get it. Could it be Java? I never see the Oracle logo when opening the file. Thx again for the help!
  • Helpful? 107
« Reply #3 on: October 14, 2010, 12:03:04 PM »
In the current version 1.27 I have dropped the Webbot splash screen as it has caused problems with some firewalls.
What you could try (I'm on XP so not sure if Windows 7 still has this stuff) is go in to Control Panel, Add/Remove Programs, and un-install Project Designer.
Then reload it from the link at http://webbot.org.uk
It could also be that the 'jnlp' file extension is associated with another application. In which case try:-
 right click on the icon, advanced, and open with, then find the javaws.exe and say open with .
javaws.exe is normally in Program Files/Java/Version/bin
--EDIT--
You could also try pointing a browser to http://webbot.org.uk/webbotlib/ProjectDesigner.jnlp
« Last Edit: October 14, 2010, 12:23:16 PM by Webbot »
« Reply #4 on: October 14, 2010, 11:02:27 PM »
It worked Webbot, thanks! I opened the file with javaws.exe and it came right up. Problem resolved. By the way, I just began to learn programming about 6 weeks ago. Using Webbot Project Designer, I just finished programming my first robot. The project designer generated the basic initialization and I just modified it to suit my purpose. Thank you so much. Soon I will post videos of my robot in competition with the robots of the other groups in my class. The Axon 2 is a really neat microprocessor and I am encouraging the sponsor of the Engineering Club to get Axon 2 micros and install Webbot P.D. on our computers for future projects. Again, thanks for the help!
Last post February 08, 2010, 12:23:43 AM
Last post April 15, 2010, 09:06:41 AM
by Cristi_Neagu
Last post July 17, 2010, 10:43:15 AM
by sasap
Last post November 14, 2010, 06:54:46 PM
