Author Topic: Help! How send/receive data from axon 1  (Read 1022 times)
Offline HenriqueTopic starter
« on: October 16, 2010, 12:10:07 PM »
Hi again   :-X
how can I send/receive data for the axon??? through the UART
Thanks anyone who can help!
« Last Edit: October 16, 2010, 05:06:40 PM by Henrique »
Offline knossos
  • Helpful? 13
Re: Help! How send/receive data from axon 1
« Reply #1 on: October 16, 2010, 05:51:39 PM »
Have you read this yet?  SoR Microcontroller UART tutorial
Alternatively you can use WebBot's Project Designer and assign the output to the UART for a quick output.
"Never regret thy fall,
— Oscar Wilde
« Reply #2 on: October 17, 2010, 01:38:31 PM »
hmm, but in case of a connection, for example I need to send some data from the axon to my computer and then send a given computer to the axon. Since this connection is only over when I turn off the axon. Which method do you recommend?
and I need to buy extra hardware for this?
I already do connect to the axon via the usb of my computer.
« Last Edit: October 17, 2010, 02:15:01 PM by Henrique »
Offline knossos
  • Helpful? 13
« Reply #3 on: October 17, 2010, 06:04:12 PM »
UART is bidirectional.  You can use the single USB connection and communicate bidirectionally across it.  If you look at WebBotLib's servosCenter() it gives an example of this.
— Oscar Wilde
« Reply #4 on: October 17, 2010, 11:58:00 PM »
Humm alright!
Thanks a lot!
« Reply #6 on: October 27, 2010, 06:39:08 PM »
enjoying the topic
I'm programming a serial communication by the Windows API, and I have this code sending an array int to the serial port (COM), and I read the response (by the axon) in the console
  DWORD BytesLidos = 0;
   int count1=0;
   int count2=100;
   uint8_t c[LEN_BUFFER];
   while(ReadFile( hCom, c, LEN_BUFFER, &BytesLidos, NULL )){
  cout <<"data1: " <<(unsigned short)c[0]<<"\n";
  cout <<"data2: "<< (unsigned short)c[1]<<"\n";
    DWORD BytesEscritos = 0;
  int send[2];
  send[0] = ++count1;
  send[1] = ++count2;
  WriteFile( hCom, send,2, &BytesEscritos, NULL );
in AVRStudio I tryed to read the data from the serial port and send back them to read in the console in the programm above. Unfortunately I can only get the first byte stored, the second byte I can't, my question is how to receive an array of bytes sent by port com.
                uint8_t data[2];
data[0] =  GET_DATA_USB;
data[1] =  GET_DATA_USB;
uartSendBuffer(UART1, data, 2);
« Last Edit: October 28, 2010, 08:52:29 AM by Henrique »
« Reply #7 on: October 28, 2010, 02:33:11 PM »
This is how I put received data into an array:
char command[]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
//this function stores uart data into an array
//a 'r' character signals the end of a command
void get_wireless_command(void)
int data;
uint8_t count=0;
data = ZigBeeGetByte();//read from your UART
if(data!=-1)//check for wireless command
while(data!='r')//if command is not complete
if(data!=-1)//if data is available
command[count]=data;
count++;
//store the r, since it already left the loop
process_command();//data recieved, now update state
Last post October 15, 2007, 02:24:57 PM
by benji
Last post November 24, 2008, 11:03:13 PM
by airman00
Last post September 09, 2009, 08:13:52 PM
by Joker94
Last post December 26, 2009, 03:20:08 AM
by Joker94
