Author Topic: please check my source code for errors  (Read 525 times)
Offline vasuTopic starter
« on: October 19, 2010, 04:30:06 AM »
Hi all,
This is my first post, i am a begineer when it comes to software and have written this code.
Please let me know if i have made any mistake.
 // Algorithm for Attiny-861 Based Cable testing jig
// date:- 05-10-2010
  // Chip Type:- Atmega Attiny-861V
  // Clock frequency:- 8Mhz, internal
// Pending Set internal clock
  #include <avr/io.h>
 int set_portA_bit( int position,int value);
 int set_portB_bit( int position,int value);
  int main()
// Set Port A and POrt B pin 9 and 10  as output port
       DDRA=0XFF;
       DDRB |= (1<<DDB7);
       DDRB |= (1<<DDB6);
// Set PORTA and PORTB pin 9&10 as default high
     PORTA=0XFF;
     PORTB |=(1 << PORTB7);
     PORTB |=(1 << PORTB6);
while(1)
   set_portB_bit(7,0);
    delay_ms(1000);
   set_portB_bit(7,1);
   set_portB_bit(8,0);
   delay_ms(1000);
   set_portB_bit(8,1);
   set_portA_bit(8,0);
   delay_ms(1000);
   set_portA_bit(8,1);
   set_portA_bit(7,0);
   delay_ms(1000);
   set_portA_bit(7,1);
   set_portA_bit(6,0);
   delay_ms(1000);
   set_portA_bit(6,1);
   set_portA_bit(5,0);
   delay_ms(1000);
   set_portA_bit(5,1);
   set_portA_bit(4,0);
   delay_ms(1000);
   set_portA_bit(4,1);
   set_portA_bit(3,0);
   delay_ms(1000);
   set_portA_bit(3,1);
   set_portA_bit (2,0);
   delay_ms(1000);
   set_portA_bit(2,1);
   set_portA_bit (1,0);
   delay_ms(1000);
   set_portA_bit(1,1);
return 1;
int set_portA_bit( int position, int value)
// sets or clears the bit in position "position"
// either high or low( 1,0) to match "value"
// other bits are unchanged
if (value == 0)
PortA &= ~(1<<position);   // set low
else
portA |= (1<<position);  // set high
return 1;
int set_portB_bit( int position, int value)
if (value == 0)
PortB &= ~(1<<position);   // set low
else
portB |= (1<<position);  // set high
return 1;
void delay_ms(unsigned short ms)
   unsigned short outer1, outer2;
   outer1 = 200;
   while (outer1)
      outer2 = 1000;
      while (outer2)
         while ( ms ) ms--;
         outer2--;
      outer1--;
thanks
vasu
Last post September 02, 2008, 10:00:50 PM
Last post January 22, 2009, 09:31:23 PM
by pomprocker
Last post June 01, 2010, 01:01:58 PM
by teoxan
Last post January 31, 2012, 07:04:35 PM
by saba_rish91
