Author Topic: Selecting a magnetic compass  (Read 1599 times)
Offline knossosTopic starter
  • Helpful? 13
« on: October 21, 2010, 01:09:23 PM »
I am looking through my options for a compass.  This is for a personal project that does not have any strict parameters, although the robot will be loaded with sensors so the type of interface will make a difference.  I am thinking I will probably go with I2C since I will already be using a Wii Motion+ and Nunchuck but am willing to consider other options.  I will eventually be adding GPS as well.  This will be on a chassis with wheelchair motors, most likely mounted on a plastic mast approx 12" above the metal frame (approx 18" above the motors).  In addition it will have 2 forms of wireless comm, one of which will likely be WiFi amplified to about 1w (mentioned in case of known issues with noise).
So far I am looking at this Devantech with tilt compensation:
Any recommendations?
"Never regret thy fall,
— Oscar Wilde
Offline madsci1016
  • Helpful? 43
Re: Selecting a magnetic compass
« Reply #1 on: October 21, 2010, 01:17:51 PM »
I have used both the HMC6352 and the HMC6343 on my SAGAR robot. The HMC6343 also gives roll and tilt data via it's 3 axis accelerometer.
On my robot, it surfers vibrational noise from the movement, and electromagnetic noise from the motors.
Watch the 3D render of the orientation in this video:
SAGAR Autonomous Robot Waypoint Mission Interface and Vehicle Video
I doubt in my application the Devantech would be any different, as it's the application, not the compass that's causing problems. I could mount it up on a mast, but would rather not. Instead, I'm going to add a 3 axis gyro as well and combine that data to filter out the noise.
It's not shown in this video, but is works well when I move SAGAR by hand, and the motors aren't running.
« Last Edit: October 21, 2010, 01:20:47 PM by madsci1016 »
Offline DUKELancelot
« Reply #2 on: October 21, 2010, 01:18:23 PM »
I like the parallax one. http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/compass/List/0/SortField/4/ProductID/98/Default.aspx
($29.95)
The one madsci1016 recommended  is also sold by parallax at a reduce price.
Also about the wifi. Have you considered a router on the robot.
The one in the pic is a Linksys WRT54GL router. It's very hacker-friendly in that it runs Linux.
« Last Edit: October 21, 2010, 01:21:58 PM by DUKELancelot »
Before you insult someone walk a mile in their shoes. Then your a mile away from them, and have their shoes.
  • Helpful? 13
« Reply #3 on: October 24, 2010, 08:25:43 PM »
@DUKELancelot
I would probably prefer a wifi module as opposed to the router, but haven't found one with an SMA connector that I can attach my amp to.  If I don't find something I like, I have considered using one of my routers instead.
@madsci1016
I assume you upgraded to the HMC6343 for the added tilt compensation.  The one I was looking at has 3-4 degree accuracy instead of 2 degrees like yours.  From your experience, do you think the extra accuracy makes a significant enough of a difference?
As for mounting my compass, I was considering the mast method to avoid motor noise, but I hadn't really thought about vibrational noise which the mast may well amplify.  Also the mast may prove problematic depending on how I mount my pan assembly on top of the robot.
— Oscar Wilde
Offline madsci1016
  • Helpful? 43
« Reply #4 on: October 25, 2010, 07:35:01 AM »
@madsci1016
Held flat, not really. But when i tilted the cheaper one more then 10 degrees, it's reading would go crazy. Also my application didn't really need an compass that was super accurate.
Last post May 05, 2008, 01:21:04 PM
by cak
Last post February 07, 2009, 07:25:28 AM
Last post September 10, 2010, 08:23:47 PM
by rbtying
Last post December 25, 2010, 08:44:48 AM
by ratulxy
