Author Topic: HSR-5980SG: Serial feedback problem  (Read 659 times)
Offline ViborTopic starter
« on: October 22, 2010, 09:02:28 AM »
Hi!
I'm working on a humanoid project and i'm using hsr-5980sg servos to operate joints.
I'm connecting 3 servos at the same time to dsPIC UART by using a daisy-chain connection.
These servos allows serial communication. Microcontroller sends 7 bytes, the last 2 with 0x00 to pull-up the line communication and get the answer from servo. But when I'm using more than one on the same bus, I get wrong information sometimes. When I send a command, one of the bytes is the servo's ID.
Does anyone already had the same problem?
What is the correct connection between a UART and a servo?
I hope you can help me.
Miguel
Portugal
  • Helpful? 107
Re: HSR-5980SG: Serial feedback problem
« Reply #1 on: October 22, 2010, 01:47:00 PM »
I don't have any of these servos - so this is just a long shot....and apologies if its stupid!
The servos probably come with a default factory ID . So have you changed them to guarantee that each has a unique ID.
One way to check would be to test each servo individually.
Last post November 01, 2007, 05:57:59 PM
by paulstreats
Last post August 31, 2008, 08:37:32 PM
by airman00
Last post December 01, 2008, 03:25:20 AM
Last post June 06, 2012, 09:32:38 AM
by Gertlex
