Author Topic: receding wire insulation  (Read 651 times)
« on: October 22, 2010, 02:05:33 PM »
this is really starting to piss me off. the wire i just bought might as well be wrapped in shrink rap! if i turn my iron too high it recedes instantaneous while if i turn my iron lower it recedes just as fast! i don't want to pay for new wire but this is really getting to me. i don't want my board shorting and burning my now rare atmega chips or making me search half an hour for said shorts. any idea how to solder these wires without the insulation shrinking?
Next step: Give them vaginas
Offline Metal Slug 2
  • Helpful? 11
Re: receding wire insulation
« Reply #1 on: October 22, 2010, 02:49:22 PM »
Try heat sinking the wire?
Or why not just add some extra shrink wrap around the exposed bit?
« Reply #2 on: October 22, 2010, 06:28:36 PM »
i'm not sure how i would do that without leaving a big gap. as for heat shrinking it it's pretty thin stuff and it's all jammed close together so i don't think that would work
Offline madsci1016
  • Helpful? 43
« Reply #3 on: October 22, 2010, 09:22:14 PM »
you could just heat shrink over the part that becomes exposed as you solder.
« Reply #4 on: October 22, 2010, 11:59:00 PM »
Either you go too hot, or you have been very unlucky with the wire. I had such wire a long time ago and I binned the lot and bought some new stuff - life's too short for bad wire.
Alas, if you wanna keep the annoyance factor up in what should be relaxation, you could use a bit of hot glue to keep things from shorting as an emergency solution (or RTV silicone, if it has to see temperatures below freezing).
Offline photomark
« Reply #5 on: October 23, 2010, 02:34:40 AM »
I used to do some very high voltage work and on some PCBs if we had even 1mm of copper showing on the wire they would not get approved, all we did was place a piece of heat-shrink on the wire before it is inserted into the hole, after soldering it on ( with a soldering iron you could weld with ) the copper wire would be hot enough to melt the heat-shrink on its own and you got a very neat looking connection .
Last post January 03, 2008, 04:20:39 PM
by maverick monk
Last post March 09, 2008, 02:32:07 PM
Wire
Started by gorner5 Electronics
Last post May 28, 2008, 01:32:54 PM
by Brandon121233
Last post August 15, 2011, 08:07:14 AM
by Gertlex
