Author Topic: 50$ Robot Status LED  (Read 2627 times)
Offline AZ196FTopic starter
« on: June 05, 2007, 12:58:27 PM »
I'm looking at the code for the 50$ robot and wondering why turning port D4 off turns the LED on.  I think that if I could understand this, I might understand a lot more about i/o.
Offline razvanc_roro
Re: 50$ Robot Status LED
« Reply #1 on: June 05, 2007, 01:01:10 PM »
I understood that if you put D4 low, LED turns on. :)
Try do your best without doing anything! Possible?!?
« Reply #2 on: June 05, 2007, 01:10:21 PM »
When you wired up the LED, you have one end connected to + of the battery.
The other end is connected to D4.
So if D4 is also high (+), nothing will happen to the LED since both ends are + and +.
When you set D4 to low (-), you then have a voltage difference across the LED (+ and -), turning it on.
If you instead wired one LED end to ground (-), and the other to the D4 pin, when D4 goes high it is powering the LED - potentially bad. Its better to use the above method so that the battery directly powers the LED and not the microcontroller.
« Reply #3 on: June 05, 2007, 01:12:04 PM »
Thank you, that's exactly what I needed to know!  Much Thanks!
Last post March 27, 2007, 01:39:43 PM
Last post June 04, 2008, 09:57:05 PM
by brian
Last post February 19, 2010, 07:53:16 PM
by legobot
Last post July 06, 2010, 04:44:21 AM
by Alfa_Zulu
