Author Topic: WeBotLib and LED / AxonII wiring question  (Read 618 times)
Offline KelpyTopic starter
« on: October 26, 2010, 09:09:42 AM »
Probably another dumb question, but here goes.
I'm using the excellent WebBotLib Project Designer for a project, which uses some LED's on my AxonII.
The designer assigns 2 pins to an led, A0 signal and A0 live+.
I'm confused, as I expected a connection to the ground pin as well.
Does this mean when I use software to activate the led, the signal pin becomes a ground pin, and the circuit is completed?
  • Helpful? 107
Re: WeBotLib and LED / AxonII wiring question
« Reply #1 on: October 26, 2010, 12:36:29 PM »
Yep thats correct. When the signal pin goes low it is 0v ie ground. So the current flows from the +ve through the LED+resistor to the signal pin.
« Reply #2 on: October 26, 2010, 01:11:12 PM »
Thank you, once again, Webbot. Wanted to be sure before going live ;)
Last post August 24, 2009, 02:17:06 AM
by WhomBom
Last post May 04, 2010, 05:48:36 PM
Last post June 17, 2010, 01:32:39 PM
by Webbot
Last post August 30, 2010, 12:26:09 PM
by tzankoff
