Author Topic: Everything you need to know about solar power  (Read 690 times)
Offline z.s.tar.gzTopic starter
  • Linux Guru
« on: October 27, 2010, 10:58:30 AM »
This thread consists of twelve things that everyone who's looking into solar power for robots needs to know but that I haven't seen anywhere.
Note: this "tutorial" assumes you know what a solar panel is and the difference between a panel and a cell along with having a basic understanding of the math behind electronics.
1. The most important thing you need to know is solar panels are weak. Solar panels produce a ridiculously small amount of power (forget about fitting a 10W panel onto a robot, it's just too big.
2. Whatever the panel is rated for is about twice what you will realistically get. The most you can hope for from an 8V panel is around four to five volts under direct sunlight.
3. Solar panel power directly correlates to size. You already know this but what you may not have thought of is the fact that you need a bigger robot to hold this panel. Bigger robots are heavier. Heavier robots need more power to move and thus a cycle appears. You will always have to make the panel bigger than the chassis otherwise it just won't work.
4. Don't be cheap. Four separate panels will never produce the same power as one panel of the same surface area simply because of the wasted space on the edges. Also remember that you get what you pay for.
5. DC/DC converters are your best friend as they are the only way to reliably get a large amount of power out of a panel. Don't think you can buy a 0.5V panel and step it up to 6V though. You'll lose all of your power to inefficiency. The best thing to to is get way more panel than you need and step it down. For example say you needed 6V@1A for whatever. You would need to buy a 18-24V panel which would give you a solid [email protected] (that's the ballpark you're looking at for a large panel). Using a DC/DC converter you can turn that power into 6V@1A because your input and output needs were both 6W. So I guess number five has another message: make sure you don't try and pull 8W out of a 2W panel. Physics says it just won't work.
6. How you angle the panels at the sun makes all the difference. A few degrees off can be the difference between full power and what you get on a cloudy day. Because of this fact horizontally mounted solar panels will do best at noon and worse in the morning and evening.
7. If you go with several cells as opposed to one panel you'll notice that the power reduces drastically when even one of them gets shaded. Using a single panel and converter can help out with this [citation needed]
8. Keep the cells/panel cool either via airflow or water. The sun is hot and it'll make your solar panels hot too.
9. Mount them in such a way that vibration will not be an issue as glass can break very easily (duh  :P) There is a way around this:
10. There are two kinds of panels: ones made of glass and ones made of epoxy. Always get the epoxy ones if you can because of two things: they don't shatter and you can drill them for mounting. Epoxy ones also don't seem to get as hot but that's a major [citation needed]
10 and a half: There is another school of thought where the panel is stationary and the robot simply goes over to it to get a charge every once in a while. Personally I think it's not that much harder to make it chassis mounted but you do whatever you want.
11. You can use mirrors and lenses to increase the efficiency of the panel but this will add serious weight, cost, and complexity to the project as you will need cooling if you do this.
12. There are all kinds of solar cells/panels out there so shop around. The difference in power can be tenfold from one to another. (The cost will usually be tenfold too  :P)
As usual, let me know if you think of something else or if something isn't correct.
[6-12 thanks to soeren]
« Last Edit: October 28, 2010, 10:21:14 AM by z.s.tar.gz »
Offline Oller125
Re: Everything you need to know about solar power
« Reply #1 on: October 27, 2010, 01:35:48 PM »
Then how come lots of solar plants use lots of smaller ones?
Offline rbtying
  • Helpful? 31
« Reply #2 on: October 27, 2010, 08:05:56 PM »
The "smaller ones" used in solar plants are still something like 2 feet by 8 feet... much larger than whatever you would be using.  Also, the larger the panels are, the more easy they are to break - and more expensive to replace.  This is negligible for your 1'x0.5' panel, but for a $5000 2'x8'... there's a cost issue.
« Reply #3 on: October 27, 2010, 10:08:12 PM »
This thread consists of five things that everyone who's looking into solar power for robots needs to know but that I haven't seen anywhere.
6. Angling them perpendicular to a straight line from the center of the cell/panel and the light source (usually the sun) is paramount. Even a few degrees off will reduce the output drastically.
7. Panels are like a chain, not stronger than the weakest link, so in a panel of 100 cells, shading even a single of them will have a quenching effect on the entire panel.
8. Keep the cells cool (fan or water works), when temp, goes up, output decreases extremely much.
9. Mount them in a way that dampens vibrations - with a few exceptions they're very fragile.
10. Best way to use them for robotics, is to let them charge an auxillary battery at a base, where the cells position can be optimized and the 'bot can go change it's battery when needed - solar is only usefull on-board if you build with carbon fiber and other light composites, so you don't need that much power.
10a. Mirrors and/or lenses can be a good way to concentrate more sun onto a cell/panel, but remember #8 - Added bonus, you learn a thing or two about compromises  ;D
11. Choose the right cells for the application. Large differences will be seen in output according to selection - Some have a higher output in natural sunlight, but have hardly any output in the light from fluorescent lamps. Some don't seem to care that much for the wavelength. Some output a few percent (of received photonic power) some output more than 20% - that's a huge difference when you consider the lack of space. Some are a very bendable film and can thus be used on odd shapes as "wallpaper" or as small ultra-lightweight panels.
12. Quality costs.
13. Never be afraid to experiment! (But do so within the borders of sanity and the unforgiving laws of nature).
« Last Edit: October 27, 2010, 10:13:35 PM by Soeren »
« Reply #4 on: November 11, 2010, 04:23:23 PM »
Actually, not nearly 'Everything you need to know about solar power' ;D
I've begun working on my first space robot, and having been thinking of solar power (just because). But then I'm like . . . will it work fine at -60 C or without atmosphere to cool it down at 100C? If anyone ever runs into practical design information for space-based solar panel robots, feel free to send 'em my way ;D
And yes, admin needs to show off with new insane robots to keep his street cred. :P
(don't ask for details, just stay tuned)
I'll verify this for you.
The reason is that when you have cells in series, the current through each must be equal (current in = current out). If a single cell is mis-performing, it'll cause all others to mis-perform (ie weakest link in the chain). If you string a bunch of solar cells together, like a good one and a crappy/shaded one, the current will match that of the crappy one.
If you put them in parallel, the output voltage must be equal. The good one will be sinking power into the crappy one (or shaded one), wasting lots of power.
  • Linux Guru
« Reply #5 on: November 11, 2010, 11:31:39 PM »
Ahh this is why they always put a diode when using solar to charge batteries.
And for the practical aspect of this forum, I believe it is everything.  :P
« Reply #6 on: November 12, 2010, 05:41:02 AM »
HI,
It is to avoid the battery discharging through the solar panel when the latter doesn't generate a voltage potential that is higher than (or at least equal to) the battery voltage potential.
Offline Spoil9
« Reply #7 on: November 12, 2010, 10:38:40 AM »
If more information is really needed about solar panels, I have found that http://www.solarpowerforum.net/ is a helpful place.
Admin, I'm also a ham radio geek. I am starting to get into working FM satellites with my hand held ham radio and have found http://web.me.com/clintbradford/Work-Sat/Sat_Skeds.html to be a helpful site. They have links to the groups that built, own, and maintain ham radio satellites. Perhaps you can contact these groups and find out what they did to power their satellites as most of these groups (although not all) are very poorly funded.
- Will
Knowledge is Power. Power Corrupts. Study Hard. Be Evil.
Last post July 23, 2008, 08:26:24 PM
by Gertlex
Last post November 22, 2008, 02:23:44 AM
Last post March 05, 2009, 07:03:26 AM
by dellagd
Last post December 14, 2009, 10:29:40 AM
