Author Topic: power to the bot  (Read 817 times)
Offline acrsTopic starter
power to the bot
« on: October 29, 2010, 05:01:41 AM »
I have a 10.8 volt, NI-CD 1200 mAH battery that i want to power my arduino based robot i tried a LM7805ACT
5v Linear Regulator but the battery burns the Regulator and SN754410NEh-bridge
i did some reading on Ohm's Law but iam lost can someone help me
Re: power to the bot
« Reply #1 on: October 29, 2010, 09:10:35 AM »
How exactly did you connect things?
(Hard to say what went wrong if you keep that a secret ;))
Offline madsci1016
  • Helpful? 43
« Reply #2 on: October 29, 2010, 09:26:59 AM »
Since you seem to like posting the same thing on multiple forums, since you are powering the H-bridge from the regualtor, my guess is you are overloading the regulator.
Are your motors 5V as well? or 12V motors?
« Reply #3 on: October 29, 2010, 11:26:07 AM »
12V motors
ok i found out why the regulator burned
but i want to use the battery to power the arduino and the SN754410NE h-bridge
the motors need more then 5v can i power the SN754410N with the battery with out burning it
the SN754410NE can take 5v to 12v can someone tell me how to connect the SN754410NE to the battery
and the arduino with out the regulator
« Last Edit: October 29, 2010, 11:43:51 AM by acrs »
Offline rbtying
  • Helpful? 31
« Reply #4 on: October 29, 2010, 12:15:25 PM »
Take a look at the datasheet.  If I remember correctly, Vcc1 is logic voltage (regulated +5v), while Vcc2 is motor voltage (direct from battery).  Look up tutorials for the L293D - it has the same pinout on the chip, and is more well documented.  Have fun, and good luck!
« Reply #5 on: October 29, 2010, 02:24:20 PM »
ok i got the robot to run 2 different ways
1.the arduino is powered by a 9v battery and the SN754410NE is powered by the 10.8 v battery
2.the arduino and SN754410NE powerd by the 10.8 v battery
but the bot moves very slow both ways
the motor are from a rc car how to give the motor more power
i had to change the drive motor on the car because  i connected the 10.8 v battery to the motor and it fried
here is a vid and pics of the setup
power to the bot
power to the bot 2
« Last Edit: October 29, 2010, 02:31:27 PM by acrs »
Last post February 07, 2008, 08:39:31 AM
Last post August 13, 2009, 10:47:09 AM
Last post March 07, 2010, 02:39:43 AM
by cyberfish
Last post September 22, 2010, 08:48:29 PM
by rbtying
