Author Topic: fabricate Robotic arm with options to change the gripper type  (Read 2493 times)
Offline a7madeTopic starter
is it possible to fabricate 5DOF robotic arm with option to change the gripper type automatic using Servo motors??
Examples:
•   Gripper for holding hot objects (hot machined parts).
•   Gripper for holding fragile object (glass, brittle).
•   Gripper with sharp Edges to cut the materials
1 DOF base
1 DOF Shoulder
1 DOF Elbow
2 DOF Gripper
Re: fabricate Robotic arm with options to change the gripper type
« Reply #1 on: October 31, 2010, 09:11:19 AM »
is it possible ...??
yes
« Last Edit: October 31, 2010, 07:10:10 PM by waltr »
Offline photomark
« Reply #2 on: October 31, 2010, 04:22:51 PM »
Very possible and also very complicated
« Reply #3 on: November 01, 2010, 08:38:19 AM »
can i use 8051 Microcontroller in this project? if no, what type of Microcontroller i must choose?
« Reply #4 on: November 01, 2010, 01:22:40 PM »
It depends on your design parameters. It may be done with an 8051 as you only have 5 motors to control depending on how they are to be controlled and on the method and precision of any required feed-back. If your requirements are tight then you may need an 8051 for each joint but all this is just guesses since I don't know what you really need.
« Reply #5 on: November 29, 2010, 11:24:50 PM »
What kind of material i should use for the gripper that hold hot objects?
Offline Conscripted
  • Helpful? 10
« Reply #6 on: December 02, 2010, 07:29:57 AM »
Well.... Hot is a relative term. How hot are you talking? Cooking hot or melting metal hot?
« Reply #7 on: December 02, 2010, 09:44:52 AM »
... And ...
What is the maximum duration to hold these hot objects and what is the cool down time (the time from releasing one object to picking up the next).
How long can they be from the fixture point.
Materials like cast iron and stainless steel transfers heat relatively slow, but keep the heat for quite a while. Aluminum OTOH picks up the heat very fast, but dissipates it fast as well - with careful selection of materials and design/construction, it could hold metal glowing cherry red (for a certain amount of time).
