Author Topic: ATMega switch out  (Read 3546 times)
Offline 555 timer chip guyTopic starter
ATMega switch out
« on: June 06, 2007, 01:20:05 PM »
can a circuit designed for the ATMega8 also use the 168 because the ATMega168 is faster and is more powerful but I cant fine a circuit for it, all the circuits I fined are for the ATMega8! >:(
Offline rgcustodio
Re: ATMega switch out
« Reply #1 on: June 06, 2007, 02:03:42 PM »
The ATmega8 and ATmega88/48/168 family are pin compatible. So you can use the ATMega168 as a drop in replacement BUT your code might not work correctly, since the memory mapped port addresses would've likely changed. Read the appnotes for changes in the design:
http://www.atmel.com/dyn/resources/prod_documents/doc2553.pdf
Note that the appnote only discusses the ATmega88, there might be changes in b/n the family members (88/48/168) so it will also be better to read the data sheets.
HTH.
- Rommel
Online Admin
« Reply #2 on: June 06, 2007, 04:47:33 PM »
555 guy, if you look at my $50 Robot code you will notice a section called CONFIGURE PORTS in the SoR_Utils.h file.
In that same file you will see lines such as PORT_OFF(PORTD, 4);
In the makefile file you will notice a line that says:
# MCU name
MCU = atmega8
If you modify each depending on your needs, your code should work for any AVR.
« Reply #3 on: June 09, 2007, 04:32:32 PM »
thank you
Last post January 03, 2007, 01:40:30 PM
by Hal9000
Last post February 09, 2007, 06:43:27 PM
by JonHylands
Last post September 04, 2007, 09:23:25 AM
Last post May 18, 2008, 07:54:42 AM
