Author Topic: how detect black and white color?  (Read 1707 times)
Offline RoboteccanTopic starter
« on: November 06, 2010, 03:27:08 PM »
hi, we are making a SumoRobot, and we need that detect white and black color, we are using the AVR studio 4 software and axon microcontroller hardware, and a CNY70 sensor, but the AVR dont have library of CNY70 sensor and I dont know how conect and I dont know how program this sensor, this is my code.
#include<avr/IO.h>
#include "sys/axon.h"
DDRA = 0xFF;
void appInitHardware(void){
pin_make_output(C0, TRUE);
pin_make_input(A0, TRUE);
    return 0;
TICK_COUNT appControl(LOOP_COUNT loopCount, TICK_COUNT loopStart) {
if (pin_is_high(A0)){
pin_is_high(C0);
else{
pin_is_low(C0);
   return 1;
please help me.
Re: how detect black and white color?
« Reply #1 on: November 11, 2010, 10:30:48 AM »
To connect, you should first look at the datasheet:
http://www.vishay.com/docs/83751/cny70.pdf
and look at the picture in the top left.
Then you want to follow the top schematic here:
http://www.societyofrobots.com/schematics_infraredemitdet.shtml
(read the entire tutorial)
The IR sensor uses an LED, so use this tutorial to select your LED resister (R1):
http://www.societyofrobots.com/electronics_led_tutorial.shtml
And use this tutorial to select the resister on the sensor (R2):
http://www.societyofrobots.com/schematics_photoresistor.shtml
A little more reading to understand what's going on:
http://www.societyofrobots.com/sensors_color.shtml
Now in code, you want to use the analog sensor code in WebbotLib, with the device plugged into the ADC header of your Axon.
Last post August 24, 2007, 01:53:33 PM
by jhonilson
Last post July 09, 2008, 12:25:52 PM
by krich
Last post October 19, 2008, 01:29:50 PM
Last post August 18, 2010, 02:05:46 AM
by abacusdheda
