Author Topic: convert input from microphone to pwm input  (Read 1060 times)
« on: November 09, 2010, 10:35:27 AM »
so i want to detect sound from standard microphones by converting the low voltage they generate to pwm signals. i'm thinking if i use an op amp chip i could have it output either +5v or 0v so that a micro could understnd it as usefull data
« Last Edit: November 09, 2010, 05:04:39 PM by blackbeard »
Next step: Give them vaginas
Re: convert input from microphone to pwm input
« Reply #1 on: November 09, 2010, 06:50:24 PM »
I doubt that you'd get anything usable from PWM'd sound - each time you convert the signal, you loose some and that is detrimental to speech recognition (if that's what you're trying to do).
What you need for the conversion is a digital audio amplifier, and since they're now quite common, you should be able to find enough articles to study all the intricacies of such a beast.
In short, you create a very stable (think both X-tal- and amplitude control) triangle waveform running at 150+kHz (HiFi amps are running much higher). This signal is fed to a comparator along with the audio signal and the resulting output is your PWM signal.
Now you "just" need to program the controller to read 150+kHz PWM - better you than me ;D
I'd rather use an A/D-C input, unless the main purpose is experimenting and learning.
« Reply #2 on: November 10, 2010, 06:23:04 AM »
Ok I should have been more detailed in the description of my project. I am not trying to add speech recognition but sound detection. It would be used to allow a robot to hunt down noises. It wouldn't need to understand what it is hearing but when it detects a noise on one of it's two microphones it would adjust it's position accordingly.
Offline azy
« Reply #3 on: November 13, 2010, 06:18:21 AM »
I got some source code somewhere , and a standalone exe file (Freebasic, Compiles into c i think, not interpreted at run time so its fast and light as basic goes)
plug in a analogue mic in to your sound card, run the prog and then a text file is created
in the text file is a volume and a time, eg volume = 77 , time = 12:35:17
updates a couple of times a second, text file gets bigger 1 line at a time, can easily distinguish 10 different volume levels of sound. Just write a snippet of code to snoop the txt file in the language of your choice
any good to you ?
Original code was a spectrum analyzer that output to the screen in real time, i just sampled some screen pixels to get the peak volume levels at any given point in time. Butt ugly but it works !
« Last Edit: November 13, 2010, 06:31:44 AM by azy »
Last post January 25, 2010, 02:33:30 PM
by galannthegreat
Last post July 10, 2010, 02:27:14 PM
Last post August 26, 2010, 07:09:49 PM
by Razor Concepts
Last post September 24, 2010, 07:38:05 AM
by waltr
