Author Topic: how regulate voltage in axon microcontroller?  (Read 1498 times)
Offline RoboteccanTopic starter
« on: November 12, 2010, 01:03:25 PM »
hi I need regulate 5,2.5 and 0 voltages in axon microcontroller, because I have a motor DC controller that you put 5v and the motor DC turn to left, when you put 2.5v the motor DC is stop, when you put 0v(off)turn right, then I need regulate signals in the pins from axon microcontroller for I controller those motor.
Offline rbtying
  • Helpful? 31
Re: how regulate voltage in axon microcontroller?
« Reply #1 on: November 12, 2010, 02:55:36 PM »
What you really mean is how to output an analog voltage.  The easiest method is to use PWM:  a 100% duty cycle is 5v, a 50% duty cycle is 2.5v, a 0% duty cycle is 0v.  It's proportional, so take a look at the documentation.  Are you using webbotlib or the original avrlib?
« Reply #2 on: November 14, 2010, 05:36:41 PM »
Can you link us to the DC motor controller you are using?
That just sounds very odd of a way to control a motor . . .
« Reply #3 on: November 24, 2010, 11:33:03 AM »
this is the link http://www.dimensionengineering.com/datasheets/Sabertooth2x10.pdf
watch the Mode 1: Analog Input
« Reply #4 on: November 24, 2010, 01:38:27 PM »
In that case, the proper way would be to use either the RC or serial mode. You don't want to use the analog method.
