Author Topic: hyperterminal Set up seeing data problems  (Read 446 times)
Offline jagpaw0Topic starter
« on: November 17, 2010, 09:33:59 PM »
i cant get the hyper terminal to work.... halp...
http://www.societyofrobots.com/axon/axon_getting_started_hardware.shtml ,
Im doing the tutorial  getting started part #2
im stuck on step #4
where it says  Select your COM port and baud rate (115.2kbps), then click connect. You should immediately start seeing data.
not seeing any data here on the terminal!!!!!!!
Re: hyperterminal Set up seeing data problems
« Reply #1 on: November 21, 2010, 10:26:49 AM »
Are you sure you are using the right COM port?
Last post September 09, 2008, 10:05:48 AM
by ankit_ipu_niec
Last post December 07, 2009, 03:04:01 PM
by waltr
Last post August 28, 2010, 01:40:06 AM
by voyager2
Last post December 04, 2010, 09:28:43 PM
by tranzparency
