Author Topic: Altering servo Hitec HS-5745 MG  (Read 1139 times)
Offline mrcw2Topic starter
« on: November 19, 2010, 05:43:18 AM »
I am planning to use two HS-5745MG servos, that have been altered for continuous rotation, with 10 cm diameter wheels for a robot I'm building.  I am trying to work through the tutorial, but I'm stuck with the rotational speed.  The only specs I can find for the servo are:
Dimensions (mm): 29.0 x 59.0 x 52.0
Weight (grams): 161.0
Speed (sec): 0.18
Torque (Kg.cm): 15.00
Ball Raced: Yes
In the end I want to know how fast will my robot travel along the horizontal and what is the max. weight it can be?  Any help/pointers much appreciated.
Offline rbtying
  • Helpful? 31
Re: Altering servo Hitec HS-5745 MG
« Reply #1 on: November 19, 2010, 09:25:59 AM »
Speed is usually given in seconds per sixty degrees, so if each full rotation of the wheel (6 * 60) takes 1.08s, then the wheel rotates at 55.56rpm.  2 * Pi * radius = Circumference, so c = 31.415cm.
55.56rpm * 31.415cm/r = 1745.4174 cm / min
Max weight is dependent on your design.
« Reply #2 on: November 19, 2010, 12:31:15 PM »
thnx
« Reply #3 on: November 21, 2010, 07:54:48 PM »
Last post December 06, 2008, 10:54:43 AM
by Ledhed66
Last post May 11, 2010, 02:25:34 PM
by Imignant
Last post July 10, 2010, 03:44:47 AM
by Derme302
Last post May 06, 2013, 07:44:53 AM
by SUTO the G
