Author Topic: entering programming mode.. FAILED! axon  (Read 2009 times)
Offline wanglalmTopic starter
« on: November 20, 2010, 09:02:59 AM »
Please help.  I click the program button before I turn on the axon, and now I can't program the mcu anymore. Is there anyway to reset it.
« Last Edit: November 21, 2010, 09:00:34 AM by wanglalm »
Re: entering programming mode.. FAILED! axon
« Reply #1 on: November 21, 2010, 10:29:10 AM »
Can you describe the problem in detail, going through all the steps? I'm not sure what problem you are having.
« Reply #2 on: November 21, 2010, 04:47:39 PM »
I'm using a avrisp mkll programer, avr studio 4
The problem started when I try to upload a new program using isp, and forgot to turn on axon.
when I turn on axon and try to upload again, avr studio is giving me this entering programming mode failed message.
I'm getting the same message if I click on read signature, or fuses.
Offline bens
« Reply #3 on: November 21, 2010, 05:15:19 PM »
It is definitely possible to corrupt an AVR by trying to program it while it is unpowered, but I expect the avrispmkii programmer to be smart enough not to try programming an unpowered AVR.
- Ben
« Reply #4 on: November 21, 2010, 05:19:46 PM »
Check your battery voltage just in case . . .
Unfortunately this is a bug with the ATmega's, that on very *rare* occasions, if you program it without power, it'll cause a crystal fuse corruption.
Here is how you fix a bricked Axon:
http://www.societyofrobots.com/axon/axon_FAQ.shtml#brick
Also, see the diagram on page 48 of the ATmega640 datasheet.
You will need something that creates a high frequency square wave, like a function generator or another microcontroller using PWM, applied to XTAL1. Then using your ISP programmer you can change the fuse back to the crystal:
http://www.societyofrobots.com/axon/axon_FAQ.shtml#fuses
Think about it for a bit, and if you get stuck, feel free to ask.
I find it's smart enough about 2/3rds of the time. Probably has to do with partially charged capacitors on the mcu board even though it's off.
« Last Edit: November 21, 2010, 05:29:21 PM by Admin »
