Author Topic: programme for motor+encoder in pic16f877a  (Read 2100 times)
Offline rabochidTopic starter
  • From the cradle to the grave
« on: November 27, 2010, 01:58:19 AM »
hi I try to program a motor + encoder with a PIC16F877 using the timer1 interrupt the program running in the simulation (I use Proteus for the simulation) but when I implement the program ,without stopping the motor is running
speed max motor 550rev/m
encoder 120 cnt/rev
I use mikrobasic pro for pic
my code:
program Timer1_Interrupt
dim counter as word
sub procedure Interrupt()
  if(PORTC=0x52) then
  Inc(counter)               ' Increment value of counter on every interrupt
  end if
  PIR1.TMR1IF = 0            ' clear TMR1IF
  TMR1L = 0x00
end sub
main:                 ' Configure AN pins as digital I/O
 PORTC = 0x50              ' Initialize PORTB
  TRISC = 0x06                 ' PORTB is output
  T1CON = 1                  ' Timer1 settings
  TMR1H = 0x80               ' Initialize Timer1 register
  TMR1L = 0x00
  PIE1.TMR1IE  = 1           ' enable Timer1 interrupt
  counter =   0              ' initialize counter
  INTCON = 0xC0              ' Set GIE, PEIE
  while TRUE
    if (counter =1000) then   '
      PORTC = 0x40     '
      counter = 0            ' reset counter
    end if
  wend
end.
and here is my schema electrique:
Re: programme for motor+encoder in pic16f877a
« Reply #1 on: November 27, 2010, 02:03:33 AM »
sorry for the comment  :P
Offline LunchBox!
« Reply #2 on: December 01, 2010, 12:19:41 AM »
I dont know C at all yet and your description is confusing me..... but im assuming "T1CON = 1"   sets the TMR1ON bite.  if that is the case, why not do that after you have set up interrupts and cleared flags etc?
" if (counter =1000) then "      what if it is larger than 1000 when it hits that instruction?
I havn't done any C since highschool and it was only a bit of it. So im just stabbing in the dark with a spoon here.
Last post May 14, 2007, 07:31:55 AM
by fang-wei
Last post June 26, 2009, 05:52:36 AM
by guru
Last post March 01, 2010, 07:41:42 PM
Last post February 17, 2011, 08:17:25 AM
by waltr
