Author Topic: Cameras  (Read 1563 times)
Offline sdk32285Topic starter
Cameras
« on: June 08, 2007, 04:52:18 PM »
Hi
Does anyone have a good recommendation for 2,   <1 lux (ie infrared) wireless cameras. I need to be able to view the two cameras simultaneously. The FOV needs to be about or greater than 70 degrees. An 802.11 transmission is preferred but i can also use a wireless AV output if both cameras go to the same receiver. The resolution and refresh rates don't matter.
Offline hgordon
  • Helpful? 7
Re: Cameras
« Reply #1 on: June 08, 2007, 05:03:20 PM »
This one is 0.5lux, and claims to be WiFi capable, though I'm not certain what that means -
    http://www.supercircuits.com/index.asp?PageAction=VIEWPROD&ProdID=5754
There's a Sanyo that is 0.03lux and LAN interface with WiFi card expansion -
    http://www.supercircuits.com/index.asp?PageAction=VIEWPROD&ProdID=5769
Actually, you should look around the website.  We used to buy a lot of cameras from SuperCircuits.
Surveyor Corporation
  www.surveyor.com
Last post December 01, 2008, 08:38:24 AM
by dunk
Last post June 29, 2010, 08:17:13 AM
Last post June 14, 2012, 12:41:27 PM
by CameraGuy
Last post January 27, 2013, 01:39:51 PM
by jwatte
