Author Topic: RC sumo robot .. need help  (Read 2480 times)
Offline modeonTopic starter
« on: December 14, 2010, 08:23:07 AM »
my team and i are building a 50 lb rc sumo robot for a school project. we are new to this and have never had any experience with building robots.
does anyone have any advice in design or construction?
Offline Conscripted
  • Helpful? 10
Re: RC sumo robot .. need help
« Reply #1 on: December 14, 2010, 09:59:30 AM »
Hello. My advice is to keep it as simple as possible. Try to plan out your entire design before you build/buy anything. If there is a contest read the rules ahead of time. Make sure you understand them so that your not disqualified on a technicality that you missed in the rules.
Most important piece of advice is HAVE FUN
Conscripted
Offline VegaObscura
  • Helpful? 6
« Reply #2 on: December 14, 2010, 05:14:14 PM »
Does the competition require your bot to be autonomous?
« Reply #3 on: December 15, 2010, 07:54:29 AM »
thank you for the advice! :D
no, its supposed to be remote controlled
Offline koolraj09
« Reply #4 on: December 15, 2010, 10:46:24 AM »
Hi modeon,
First of all look at the arena size in which you'll play the matches. Depending upon that you need to figure out what speed does your bot requires. For Example if your arena is too small then keep the speed low/moderate(as per your choice) and vice versa..this well help maneuverability and cuts down the chances of you getting knocked off the arena. Further than this you must keep it simple,get your drive-train right and have enough torque to push the other bots out...possibly a wedge(ramp) at the front side of your robot would do. Avoid loose mounting of motors and other parts.
Well that would be it.
Best Luck and have a great time!!
Offline Conscripted
  • Helpful? 10
« Reply #5 on: December 15, 2010, 11:29:47 AM »
Never underestimate the value of PRACTICE. Spend a lot of time driving your bot when it's finished. This will minimize the "human factor". I have seen superior bots lose because of human error.
Conscripted
« Reply #6 on: December 16, 2010, 07:56:42 AM »
The area is a 15' 2" square. My robot needs to be remote-controlled and has to weigh less than or equal to 50 pounds.
« Reply #7 on: December 16, 2010, 07:59:28 AM »
do you guys recommend servo, DC, or stepper motors?
  • Helpful? 86
« Reply #8 on: December 16, 2010, 08:47:45 AM »
For a 50 pound bot Geared DC motors is really the only way to go along with a good motor controller board.
Offline tyler555
« Reply #9 on: December 07, 2011, 04:49:32 PM »
I am doing the same competition, what speed controllers do you suggest for two geared brushed NPC-41250 motors running at 24v also what batteries should I use?
  • Helpful? 86
« Reply #10 on: December 08, 2011, 10:14:19 PM »
For a 50lb remote controlled (RC) Sumo bot look into what is used for the combat bots. You are building the same thing but with different rules of engagement.
Offline tyler555
« Reply #11 on: December 09, 2011, 10:23:59 AM »
?... No I am doing the robo sumo, no weapons.
Offline tyler555
« Reply #12 on: December 09, 2011, 10:26:09 AM »
haha forget my stupid comment. I was not aware of what you meant. :P. I did look into that they are using two of the IFI VEX Pro Victor 883 with cooling fans and fan protectors.
Last post March 23, 2008, 03:55:51 PM
Last post January 20, 2012, 08:19:11 AM
by billhowl
Last post February 18, 2012, 11:49:19 PM
by aidan
Last post June 05, 2012, 02:40:32 PM
by firatdede
