Author Topic: Sensor board for a small line follower  (Read 1295 times)
Offline ConscriptedTopic starter
  • Helpful? 10
« on: December 16, 2010, 11:55:35 AM »
I'm in the design phase of a small line follower. I found this sensor and wanted to know if it would be suitable to build the line tracking sensor. http://uk.farnell.com/osram/sfh7221-z/emitter-detector-ir-880nm-smd/dp/1219694.
The plan is to use:
  • Two pager motors
  • ATTINY85
  • SFH7221 (X3)
I'm planning on running the bot at 3vdc.
Conscripted
  • Helpful? 84
Re: Sensor board for a small line follower
« Reply #1 on: December 16, 2010, 12:32:16 PM »
Nice small device. Looks like it should work.
It will probably take a little experimenting to find the optimal distance, LED current and phototransistor bias to get reliable results.
  • Helpful? 10
« Reply #2 on: December 16, 2010, 10:19:26 PM »
I could use some advice on how to use the photo transistors. I googled about a bit today but everything I found that may have given me information was blocked by the firewall. How do I connect these to the micro? Will it have to be through the ADC or can I get a simple digital input? A schematic would be great help.
Conscripted
Offline aruna1
  • I'm an Ordinary guy
« Reply #3 on: December 17, 2010, 06:56:10 AM »
pager motors are power hungry buggers.will eat your battery in minutes.and they are hard to control
I'm Me
  • Helpful? 10
« Reply #4 on: December 17, 2010, 07:15:03 AM »
I'm ok with a relatively short battery life. This is just for my own improvement. I won't be going to a contest with it. I'm currently in south dakota. There aren't any competitions within a 5 hour drive from here.
What makes pager motors harder to control then a regular motor?
Conscripted
Offline aruna1
« Reply #5 on: December 17, 2010, 08:31:47 AM »
well they just dont behave well. i guess they are not made to be controlled.just go wild and vibrate(due to attached weight of course).even with lo pwm useful speed is too high (from my experience) however if you can gear it ,it will be a different story
I'm Me
  • Helpful? 10
« Reply #6 on: December 17, 2010, 09:00:05 AM »
I'm looking at a pair of pager motors from www.solarbotics.com they don't have weights attached. They also sell geared pager motors.
  • Helpful? 84
« Reply #7 on: December 17, 2010, 09:11:54 AM »
Conscripted
Think of the photo transistors as a regular NPN transistor but with light creating the Base current. The Collector and Emitter is connected as any other NPN.
You don't need an ADC if you design the photo transistor circuit correctly. What you want is the photo transistor is be either fully off on fully on (saturated) when the sensor is over a black or white surface. Then just connect to a digital input to be read as a '0' or a '1'.
Last post October 12, 2007, 04:39:09 AM
Last post August 16, 2010, 09:51:32 PM
by Hawaii00000
Last post December 15, 2010, 10:48:47 AM
by Conscripted
Last post April 06, 2011, 08:47:52 AM
by waltr
