Author Topic: big motor tight budget  (Read 3974 times)
Offline TravelingPencilTopic starter
« on: June 09, 2007, 10:43:58 PM »
What i need is a motor that has enough power and speed to drive a screw(the kind connected to a boat's engine) that will push a 250 pound boat through the water at at least 5 MPH for under $50. I also need a small screw, say 3" diameter to be driven by the motor for under $30.
many thanks to anyone that can find a motor that fits these needs.
Offline ed1380
Re: big motor tight budget
« Reply #1 on: June 10, 2007, 07:31:15 AM »
junkyard.
 my sugestion is the blower motor from a car's heating and cooling system.
also see if you can find the screw to a boat there
Offline sotu
  • ïBB - Eye Biped Bot
« Reply #2 on: June 10, 2007, 01:46:12 PM »
So you wanna make your own boat motor?
Your pretty darn good if you can find one on that budget!
How to build a biped bot:
« Reply #3 on: June 10, 2007, 02:20:46 PM »
that might just work but my only problem is finding the motor in the car(how would i take it out of the car,where is it. i know it varies by make and model but a basic rundown would be helpful)
you are very right
« Reply #4 on: June 10, 2007, 04:16:51 PM »
what about a weed whacker off of ebay?
http://search.ebay.com/weed-whacker_W0QQfclZ4QQfnuZ1QQfsooZ1QQfsopZ1
they use it for bikes, why not boats?
[youtube=425,350]HpmZUQtpejE[/youtube]
Offline ed1380
« Reply #5 on: June 10, 2007, 05:06:09 PM »
behind/under the glove compartment. maybe more toward the driver under the dash
« Reply #6 on: June 10, 2007, 05:16:56 PM »
I am going to look into both ideas, but i'm leaning towards the weed wacker engine because it already has most of what i need(like a long output shaft to stick in the water). but then again a blower motor from a junkyard is very cheap so i might use both, one way or another
Offline dunk
« Reply #7 on: June 11, 2007, 05:43:14 AM »
you could make a mini longtail boat with the weed wacker with very little modification.
http://images.google.com/images?um=1&tab=wi&ie=UTF-8&rls=GGGL%2CGGGL%3A2006-34%2CGGGL%3Aen&q=longtail%20boat
Offline ed1380
« Reply #8 on: June 11, 2007, 07:04:33 AM »
I think I should have a blower motor left over from when i was trying to put one on a scooter. so if you want it, you can have it, if I find it.
« Reply #9 on: June 11, 2007, 11:20:07 AM »
COOL!!!
a mini longtail is a good idea but there is the question of where to get one, any sugetions
« Reply #10 on: June 11, 2007, 01:14:21 PM »
Thailand ;D
(I think Dunk was just suggesting that the design was proven and tested)
« Reply #11 on: June 11, 2007, 04:03:03 PM »
lol :)
Last post September 11, 2009, 04:09:21 PM
by galannthegreat
Last post January 08, 2010, 04:33:28 PM
by madsci1016
Last post January 25, 2010, 04:05:54 AM
by Joker94
Last post September 25, 2012, 01:02:33 AM
by senthil19
