Author Topic: UART Woes  (Read 535 times)
Offline VegaObscuraTopic starter
  • Helpful? 6
UART Woes
« on: December 30, 2010, 01:14:02 AM »
I've added UART to my $50 bot and it does a great job of sending information to my computer.  I can easily read sensor values and output them to hyperterminal flawlessly.  The problem is, I'm having a lot of trouble sending information in the other direction.  I'm trying to use hyperterminal to send information to my bot and nothing I do seems to work.  I think my problem is not in the bot or the code but rather in getting hyperterminal to send anything.  If I have my bot to constantly send something and then I bridge RX and TX, the bot receives the information its sending.  But no matter what I do, I can't get it to receive anything from hyperterminal.
I've read that all you have to do to send a character from hyperterminal is press a button and hit enter.  The problem is nothing happens when I do that.  TX on my UART module doesn't even flash.
Here's the code I'm using:
#include "interface.h"
void init (void);
u08 myReceivedByte;
int main()
  init();
  while(1)
  if (uartReceiveByte(&myReceivedByte)) {
               rprintf("Pressed: %d\n", myReceivedByte);
  return 0;
UART gets initialized in interface.h.  I have no idea what to try at this point.  Everything works fine when I'm sending data from the bot to hyperterminal, and the bot works fine when I try a loopback by bridging rx and tx.
Offline hopslink
  • Helpful? 14
Re: UART Woes
« Reply #1 on: December 30, 2010, 08:20:28 AM »
How have you configured flow control for your port in Hyperterminal? This should be set to NONE for basic comms. Sounds like yours may be set to Hardware?
  • Helpful? 6
Re: UART Woes
« Reply #2 on: December 30, 2010, 01:33:08 PM »
Fixed.  +1.  Thanks.
Last post February 25, 2007, 04:51:00 PM
Last post June 04, 2009, 10:43:24 AM
by Resilient
Last post January 08, 2011, 09:34:23 AM
by TrickyNekro
Last post December 14, 2012, 10:59:24 AM
