Author Topic: hall effect switch as encoder  (Read 999 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
« on: December 31, 2010, 06:25:45 AM »
hi I was wondering can i use these hall effect sensors to make a wheel encoder.they are from ebay.
http://cgi.ebay.com/5pcs-NEW-A3144-A3144E-OH3144E-Hall-Effect-Sensor-J-/150503466115?pt=LH_DefaultDomain_0&hash=item230ab4a483
I want to know if i attach them in motors body can i use it to count rpm of the motor?
thank you
I'm Me
Re: hall effect switch as encoder
« Reply #1 on: January 01, 2011, 06:27:49 PM »
no one? ???
I'm Me
  • Helpful? 84
« Reply #2 on: January 01, 2011, 10:10:39 PM »
It can be used but will require some addition support circuits such as amps. It will also require finding the correct placement on the motor to pick up the rotating magnetic field of the stator.
This is not a common method to measure the rotational speed of a motor. Probably due to the difficulty.
« Reply #3 on: January 01, 2011, 10:15:14 PM »
this is a hall effect switch so i guess i dont need amplification right?
I'm Me
« Reply #4 on: January 02, 2011, 11:59:44 AM »
Hall switches is used extensively in brushless motors - take a look at some of their datasheets to see how.
Take a close look at the datasheet of the (obsolete) Hall switch you are planning on using - and check its sensitivity in relation to the rotating magnet field of the motor.
Last post March 09, 2008, 06:02:39 AM
Last post January 23, 2012, 05:42:13 PM
by omkar
Last post February 24, 2011, 12:21:41 PM
Last post November 12, 2012, 02:48:01 AM
by newInRobotics
