Author Topic: Problem with interfacing PS2 controller with PIC24f  (Read 1324 times)
Offline averafterTopic starter
« on: January 04, 2011, 02:12:49 AM »
Hi all, I faced some problem when interfacing PS2 controller with PIC24FJ256GB110 through SPI. I use PIC C compile to write the program, and the code is attached below. Unfortunately there was not data reply from the ps2 controller, can anyone give me some guidance what to check? Besides that, I would like to ask is PS2 controller compatible with 3.3V or not? Because the output of the controller is 3.3V, will is cause any problem?
Here is the code:
//Peripheral Pin Select Pin Definition
#pin_select SS1OUT=pin_b14    //Pin 44
#pin_select SDI1=pin_d14      //Pin 47
#pin_select SDO1=pin_d15      //Pin 48
#pin_select SCK1OUT=pin_f4    //Pin 49
//Funtion Declaration
void ps2(void);
int8 reverseByte(int8);
//I/O Pin Defination
#define  ps2CMD PIN_D15
#define  ps2ATTN PIN_B14
#define  ps2DATA PIN_D14
#define  ps2CLK PIN_F4
//Variable Declaration
int8 ps2Byte[9];
int8 ps2Status;
void main()
{     setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4);
   SPIEN=0;
   CKP=1;
   CKE=0;
   setup_spi2(SPI_SS_DISABLED);
While(true)
Restart:
    ps2();
  ps2Status = reverseByte(ps2Byte[2]);
   if(ps2Status == 0x5A)
      //restart_wdt();
      Output_high(Pin_F0);
      delay_ms(1000);
   else
      goto restart;
void ps2 (void)
   SPIEN=1;
   output_low(Pin_B14);
   delay_us(20);
   ps2Byte[0]=spi_read(0x80);
   ps2Byte[1]=spi_read(0x42); //get controller ID
   ps2Byte[2]=spi_read(0x00); //response from controller
   ps2Byte[3]=spi_read(0x00); //ps2 left button
   ps2Byte[4]=spi_read(0x00); //ps2 right button
   ps2Byte[5]=spi_read(0x00); //right joystick - x axis
   ps2Byte[6]=spi_read(0x00); //right joystick - y axis
   ps2Byte[7]=spi_read(0x00); //left joystick - x axis
   ps2Byte[8]=spi_read(0x00); //left joystick - y axis
  output_high(Pin_B14);
int8 reverseByte(int8 x)
x = (x & 0x0F) << 4 | (x & 0xF0) >> 4;
x = (x & 0x33) << 2 | (x & 0xCC) >> 2;
x = (x & 0x55) << 1 | (x & 0xAA) >> 1;
return(x);
Last post January 06, 2007, 09:54:32 AM
by boney
Last post May 07, 2009, 03:49:52 PM
by SmAsH
Last post May 31, 2009, 12:35:58 PM
by Swarmed
Last post August 09, 2010, 10:37:18 AM
by kupter
