Author Topic: Tadiran cells.  (Read 1527 times)
Offline ballbreakerTopic starter
Tadiran cells.
« on: January 04, 2011, 11:39:07 AM »
i have been looking for good batteries and as i was about to choose between LI-ion or LI-Poly i found this kind of batteries Tadiran Batteries i couldn't find a lot of information about them so if anyone knows them pls tell me some info like if there are recharchable
thank you
For Those About To Rock, We Salute You!
Re: Tadiran cells.
« Reply #1 on: January 06, 2011, 12:24:05 AM »
Posting (links to) what you found would make it a whole lot easier to help.
Offline DJSprocket
Re: Tadiran cells.
« Reply #2 on: January 06, 2011, 06:25:24 AM »
find the model number of the battery you are looking for on this page
http://www.tadiranbat.com/index.php/product-spec-sheet-directory
and it should have a full datasheet including rechargeable yes/no
charge/discharge life cycles
max temp min temp... etc etc
Offline blackbeard
Re: Tadiran cells.
« Reply #3 on: January 06, 2011, 06:42:22 AM »
fyi i'm pretty sure that's a brand of batteries not an actual battery type. lipo is good but hard to work with and lithium is similar although less dangerous. nicad should be avoided as it is pretty much obsolite but nimh for me has proven to work wonders.
Next step: Give them vaginas
Re: Tadiran cells.
« Reply #4 on: January 06, 2011, 05:59:21 PM »
[...] nicad should be avoided as it is pretty much obsolite but nimh for me has proven to work wonders.
Don't write off NiCd cells. For some applications they are the best choice. NiMH have a larger capacity, but NiCD can deliver several times more current.
Offline Joker94
  • Helpful? 26
Re: Tadiran cells.
« Reply #5 on: January 06, 2011, 10:12:49 PM »
It is common for RC planes to use NiCad batteries for that very reason.
