Author Topic: Need to control the hour and minute hands for a fake clock.  (Read 5304 times)
Offline Bill 79268LSTopic starter
« on: January 09, 2011, 11:05:10 AM »
I need to control the speed of a fake clock that will be used in a Nutcracker play for this coming December. I want to use the small motor that is in a remote control car and attach one of the wheels to the center of the clock hands but I want to control the speed of the clock hands.
Thank you.
Re: Need to control the hour and minute hands for a fake clock.
« Reply #1 on: January 09, 2011, 11:42:59 AM »
This sounds to be a good job for a stepper motors and a processor such as any of the AVRs.
SparkFun has stepper motor, stepper drivers and processor boards.
« Reply #2 on: January 09, 2011, 03:29:26 PM »
Waltr
Thank you for your reply. I sent an email to SparkFun requesting some help and hope to hear from them soon.
Bill
Offline klims
« Reply #3 on: January 09, 2011, 10:43:52 PM »
To do this you will need one of the more expensive remote control car radios(transmitter) because they give proportional output. This means that if you squeeze the trigger a little bit then the motor spins slowly. Do you know anyone with a radio like this? Worst case they are not expensive to buy a cheap one.
If you wanted to go this way you would need:
1. proportional radio transmitter
2. receiver
3. ESC (electronic speed controller)
4. battery
5. motor.
« Reply #4 on: January 10, 2011, 09:45:53 AM »
  klims,
 Thank you for your help. I think you're right about using the more expensive remote control car. I'll keep everyone posted on my progress.
  Many thanks,
  Bill
« Reply #5 on: January 17, 2013, 02:13:44 PM »
   I found a way to control the hour and minute hands for a fake clock.  I attached the shaft of the gear motor (GM17)
from Solarbotics to the gear that turns the hour and minute clock hands of a small battery operated clock. The gear
motor is a small, slow power motor that turns from 12 to 46.9 RPM's depending on the voltage used. Solarbotics can
be found on line. The item costs $7.00.
« Reply #6 on: January 17, 2013, 02:16:43 PM »
  I forgot to mention in my last post that I used the electronics and transmitter from a small remote controlled toy car.
