Author Topic: Photovore DD Drive Robot programming tips  (Read 1352 times)
Offline Elijah5647Topic starter
  • Mwahaha
« on: January 12, 2011, 02:20:06 PM »
Hey this code is for my differential drive robot with photoresistor sensors. It seems to work  ok but does anyboby have any tips to make it better??
#include <Servo.h>
Servo servo_left;   // create servo object to control a servo
                   // a maximum of eight servo objects can be created
Servo servo_right;  // create servo object to control a servo
int ledPin = 13;                // LED connected to digital pin 13
void setup()                    // run once, when the sketch starts
 servo_left.attach(9);  // attaches the servo on pin 9 to the servo object
 servo_right.attach(10);  // attaches the servo on pin 10 to the servo object
 pinMode(ledPin, OUTPUT);      // sets the digital pin as output
     int sensor_left=0;//left photoresistor
     int sensor_right=1;//right photoresistor
     int threshold=8;//the larger this number, the more likely your robot will drive straight
void loop()
     digitalWrite(ledPin, HIGH);   // sets the LED on
//store sensor data
     sensor_left = analogRead(0);            // reads the value of the left photoresistor (value between 0 and 1023)
     sensor_left = map(sensor_left, 0, 1023, 0, 255);     // scale it to use it with the 8bits (value between 0 and 255)
     sensor_right = analogRead(1);            // reads the value of the right photoresistor (value between 0 and 1023)
     sensor_right = map(sensor_right, 0, 1023, 0, 255);     // scale it to use it with the 8bits (value between 0 and 255)
           //detects more light on left side of robot
           if(sensor_left > sensor_right && (sensor_left - sensor_right) > threshold)
                 {//go left
                 servo_left.write(0);
                 servo_right.write(150);
           //detects more light on right side of robot
           else if(sensor_right > sensor_left && (sensor_right - sensor_left) > threshold)
                 {//go right
                 servo_left.write(150);
                 servo_right.write(0);
           //light is about equal on both sides
           else
                 {//go straight
     delay(25);                       // waits 25ms for a small delay to prevent crazy oscillations
     digitalWrite(ledPin, LOW);    // sets the LED off
Offline Crunchy Theory
  • "Well great is ok, but amazing would be great."
Re: Photovore DD Drive Robot programming tips
« Reply #1 on: January 12, 2011, 02:58:08 PM »
I don't have the code with me right now, but I can give you some ideas:
1) Have the robot calibrate itself based on the ambient light in the room when the robot first turns on and base its light detection off that. This way it'll work in a bright room or a dark room and not have problems with a static difference threshold.
2) Try to implement different kinds of movement functions. For example, have the robot start out with a wide turn as it first detects a shadow and make the turn sharper the longer it stays in the shadow. I just thought of this now, actually, and I'll probably try it when I get home   ;D   In theory, I think it should work around the problem of hitting a shadow edge dead-on (where the same amount of darkness is detected by both sensors, so the robot continues forward), and maybe smooth out the motion a bit.
3) Get the IR rangefinder sensor. It makes the robot a-whole-nother beast and is really interesting to play around with. I implemented mine without the servos (stationary on the front of the chassis). I used this so that my robot can avoid obstacles as it's searching for light. If you program the robot to move forward in a subtle 'S' pattern, you can create a field of detection that is wide enough to keep the sides of your robot from hitting anything (accounting for the narrow width of the IR beam). Works pretty well on mine!
The only way to top an upright screen, keyboard, and mouse is to eliminate the need for humans to touch a PC at all. Oh, hello there Mr. Robot... what would I like you to do, you ask?
