Author Topic: Servo Cycle Lifetime  (Read 5736 times)
Offline AdminTopic starter
« on: June 12, 2007, 01:55:06 PM »
I plan to do some genetic algorithms on a robot that uses servos to actuate.
Here is the problem:
Genetic algorithms require days and months of continuous actuation, and in my case I calculated 3.5 straight days is enough to get the data I need.
So the question:
Does anyone know the lifetime of a servo, ie number of times it can reverse direction (medium load) till it breaks? (Im using the Futaba S3110)
Anyone had a servo break from continuous use and can tell me the servo name and an estimate number of cycles before failure? (rough treatment doesnt count)
(I guess I will need to run a break test on a few servos and see how they fare)
Offline hgordon
  • Helpful? 7
Re: Servo Cycle Lifetime
« Reply #1 on: June 12, 2007, 02:02:00 PM »
It's probably been 5 years since we ran these kinds of tests, but we were using Hitek servos for a webcam pan/tilt, and found that the resistive film on the feedback potentiometer would wear out very quickly on the HS311, but units with the HS422 servo stayed in service for years.  The durability of the resistive film was a much more significant factor than metal gear vs bushings.  You might want to take apart some servos to inspect this feature.
Surveyor Corporation
  www.surveyor.com
Offline maverick monk
« Reply #2 on: June 12, 2007, 02:36:57 PM »
my rc car has had its front wheels going back and forth for 2 years, ill figure i drove it about 2 hours a week and thats with the weight of a 1.5 lbs car pushing the wheels at about 20mph... so, with medium resistance on a nice servo like that futaba id guess, 300+ hours of continual function, assuming the motor dose not overheat and grit dose not cause the gears to wear
« Reply #3 on: February 03, 2008, 11:47:43 AM »
A quick report of a servo failure:
HS-225MG . . . supposedly it was supposed to have all metal gears, but then the servo started making clicking noises.
Opening it up, I found that all but one gear was metal - its the second gear after the motor shaft gear. Apparently its plastic, and literally half the teeth have been stripped from it.
I was using it as a wheel motor, so no high forces were ever applied to it. I'd say the servo has experienced a subjective 'medium' amount of usage.
« Reply #4 on: March 31, 2008, 08:20:02 PM »
Another servo failure report . . . the HS-225MG again!
This time its the little metal pin that somehow snapped off on its own. It appears they redesigned the metal pin to have a much smaller diameter where it inserts into the gear . . . I was lucky to have an extra gear set for the last time a gear broke. And I'm not abusing this servo either! not acceptable . . . I think I'm gonna write Hitec, they've answered previous emails of mine . . .
And as I mentioned in another post, another HS-225MG went up in smoke literally when accidently reversing battery polarity for a second . . .
« Reply #5 on: April 06, 2008, 10:53:45 AM »
Man, yet another HS-225MG failed :'(
My replacement gear broke in the servo that just recently broke.
Hitec never replied to my email about this problem . . .
I'm no longer buying this servo again, and will try other brands from now on.
bad product + bad service = lost customer :-X
« Reply #6 on: April 17, 2008, 04:12:04 PM »
Another HS-225MG just went up in smoke today (literally), and I wasn't abusing it or anything! :'(
I got four left, lets see how long it takes for them to fail . . .
« Reply #7 on: April 17, 2008, 04:50:27 PM »
Hmmmm I believe I'm cursed.
Only 30 minutes since the last failure, and I already have another broken servo :'(
This time the HS-645MG. Funny thing tho . . . the gears didn't break, but the plastic casing where the stopper is broke!
I'm really starting to think Hitec servos are low quality . . .
With the exception of one servo, all these failures are occuring on my robot arms (that are only supporting its own weight) . . . I'm thinking Hitec servos aren't design for sudden electrical or mechanical shocks . . .
Offline Spoil9
« Reply #8 on: April 17, 2008, 04:55:56 PM »
Admin,
Is Hitec servo's all you have bought in the past? If so, is this a new thing that they are failing cause it might just be a bad batch or something.
Knowledge is Power. Power Corrupts. Study Hard. Be Evil.
« Reply #9 on: April 17, 2008, 05:27:45 PM »
I also buy futabas and they break too - but I abuse and mod my futaba servos so its understandable.
There is always a chance Hitec has changed their manufacturing methods or swapped to shoddy components/manufacturers . . . in either case, they never replied back to me.
I was hoping I could avoid this, but I guess I need to rewrite my servo control algorithms to smooth it from shocks . . . a lesson for all of us - don't do ninja moves with robot arms! Should be more Yoga like . . .
Offline AndrewM
« Reply #10 on: April 17, 2008, 06:00:56 PM »
When it comes to taking over the world, Yoga moves are just not going to get the job done
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
Offline Asellith
  • Helpful? 9
« Reply #11 on: April 18, 2008, 06:28:15 AM »
You know what this means admin. After you complete your Axion run its time to design and build your own super servo!
Jonathan Bowen
CorSec Engineering
www.corseceng.com
Offline ALZ
« Reply #12 on: May 03, 2008, 12:29:15 AM »
Hi: I think maybe you want to much from them. Look at all they have to do in that small space. The gears are so thin and the chips really don't have any place to get rid of the heat. No wonder they don't last long. For the money you spent on blowing out servos, you could have use a gearbox motor and built a bridge driver. I know a servo is taking the easy path.
« Reply #13 on: May 03, 2008, 05:57:25 PM »
I used them within the specs on the datasheet. I didn't abuse them. If I abused them, which sometimes I do, then it'd be ok if they failed . . .
You forgot that I also need a feedback position sensor, control electronics, and a mount for it. Not so simple . . . I'm building a robot here, not a servo :P
Anyway, I figured I'd upload what a fried servo looks like. Not too exciting . . . the top servo is undamaged, the bottom one smelled all burnt like . . .
« Last Edit: May 03, 2008, 05:58:45 PM by Admin »
Offline ALZ
« Reply #14 on: May 04, 2008, 12:07:41 AM »
No, I didn't forget. Who ever said making a robot was easy? not me! At some point if you want to make a robotic arm that can lift more than a small ball  you have to get away from useing RC servos.
"You forgot that I also need a feedback position sensor, control electronics, and a mount for it. Not so simple . . . I'm building a robot here, not a servo "
« Reply #15 on: May 04, 2008, 07:16:24 AM »
Actually, based on my calculations and the specs on the servo datasheets, the two robot arms on my ERP can allow it to do pullups - serious. But, given the failure rate and cost of the servos, I wouldn't actually try that . . . There are some fairly beefy servos out there, I could have my bot do some heavy lifting with those before I'd need to move to stronger servo-fied DC motors. But I have a personal preference towards small robots that can work well with hobby servos - cheaper and easier.
Oh, and my ERP has 11 servos on it, and will have 3 more soon - very expensive if I used servo-fied motors!
(servo-fied should be a word)
Offline Metal Slug 2
  • Helpful? 11
« Reply #16 on: February 15, 2009, 12:12:42 PM »
I agree.  After building my $50 robot i noticed that when i turned it on the bot would surely by photovoric (is that even a word?) and everything, but when it would turn to avoid a shadow either servo would suddenly jolt in the opposite direction.  when i had modded the HS-311's i noticed how fragile the nylon gears were and after seeing the sudden forces applied to them i decided to modify the original photovore code so increase the servos life.  I just changed the servo speed values so that when turning only one servo moves to turn the bot and the other remains still, so the bot basically pivots on the non-moving wheel.
Last post March 26, 2008, 04:19:55 PM
by benji
Last post May 25, 2010, 05:16:58 PM
Last post August 17, 2010, 06:37:29 AM
by Kerry
Last post December 19, 2010, 10:12:51 AM
by kurukshetra
