Author Topic: Axon and resistive force sensor  (Read 468 times)
Offline mstachoTopic starter
  • Helpful? 10
« on: January 13, 2011, 09:53:04 AM »
I'm thinking of getting a few resistive force sensors -- the ones that change their resistance when a force is applied.  In order to read from them, I'd have to supply a voltage, is that right?  Can the axon just read resistance at its analog inputs, or do I have to make a reading circuit for the sensor that measures voltage drop across it?
MIKE
Re: Axon and resistive force sensor
« Reply #1 on: January 13, 2011, 10:09:48 AM »
ADC only reads voltage, so you need to create a voltage divider to know resistance.
Follow this tutorial:
http://www.societyofrobots.com/schematics_photoresistor.shtml
but instead of light changing resistance, you have force changing resistance. Works exactly the same.
Also good reading:
http://www.societyofrobots.com/sensors_forcetorque.shtml
If the signal is very small, you'll need to amplify it using an Op-Amp, or a Wheatstone bridge.
Last post July 16, 2007, 02:38:44 AM
by hazzer123
Last post November 17, 2007, 07:15:05 PM
by Hester EE
Last post April 25, 2010, 05:25:31 PM
Last post January 18, 2013, 04:39:19 AM
by mjrobotics
