Author Topic: wifi communication  (Read 918 times)
Offline dan87Topic starter
wifi communication
« on: January 16, 2011, 07:48:37 AM »
Hi Guys,
I finished building a remotely controlled car using the rabbit 3710 microcontroller that is controlled while its connected to the PC using serial to usb converter.
now I want to control it through wifi??
As you now the RCM3710 doesn't have a wifi module so i bought a netgear router with wifi and connected the microcontroller to the router using ethernet.
I tried to run the code no errors but i cant issue commands to the car.
Please help me to solve this issue:
.how to configure the router DHCP...etc
.what is needed to written in Dynamic C to connect successfully.
Thanks guys,
Re: wifi communication
« Reply #1 on: January 16, 2011, 08:18:36 PM »
18 views and no reply!
Offline Robots_Australia
« Reply #2 on: January 19, 2011, 07:54:46 AM »
Pc Networks need TCP\IP for web based communications but Networks require IPX\SPX\Netbios... you might want to look into the Netbios side??
The Brain is a Computer that Creates a Program called Mind - Unknown
