Author Topic: My first robot  (Read 5460 times)
Offline hazzer123Topic starter
My first robot
« on: June 13, 2007, 01:33:39 AM »
Ok before my exams i made a simple photovore. It wasn't that impressive... I decided to make it avoid all the objects in its way instead. But I had to start revising.
Now ive finished my exams, i decided to clean up the code and put it in a more permanent chassis. Sure, its not the most sophisticated thing in the world. But it didnt cost much, and i learnt a load making it.
It uses two homemade IR detector/emitter pairs to detect objects. It has two hitec servos for drive. Powered by a Ni-Cd battery from my brothers R/C car. The microcontroller is a PIC16F876A using a bootloader. The chassis is salvaged froma floppy drive.
I would post the code, but its not well commented. I will clean it up and post it.
It works by creating distance thresholds when powered on. It samples the sensors, and then will turn accordingly if there is a big change in one of the sensors.
Here is a video -
[youtube=425,350]xnJuK3IqwKE[/youtube]
The attached pictures are-
1) With the old cardboard chassis.
2) During rebuild with the floppy drive case.
3) Finished rebuild.
« Last Edit: June 13, 2007, 01:35:18 AM by hazzer123 »
www.icrobotics.co.uk
Offline Hal9000
Re: My first robot
« Reply #1 on: June 13, 2007, 04:07:44 AM »
Hey that's pretty neat man, well done! It's nice to see stuff after tralking to you about it lol :)
Umm, yeah, all I can say is that tidying up the chassis and getting some proper wheels might be a good idea. Some sort of modularity for adding new sensors etc.
I often think that a good way to do this is get some lego technic and use all the axles through hole blocks to attach stuff to. Very nice indeed.
Offline Ai-bot
Re: My first robot
« Reply #2 on: June 14, 2007, 09:19:52 AM »
Hi
that is pretty good for your first robot.
Look forward to see more of your robots in the future.
Re: My first robot
« Reply #3 on: June 14, 2007, 09:31:05 AM »
Hi
Thanks for your comments :)
I plan on making it into a micromouse. But the thing i need first is a more powerful controller.
I have a few PIC18F4520s with hardware multiply, but my programmer velleman k8048, doesnt support them. They are supposedly supported if i use Winpic, but i have had no success.
I dont have the money for a new programmer. Hmmmm i was thinking if i could send a couple of chips somewhere to get flashed with a bootloader... Is there anywhere i can do this?
Offline Camtron
Re: My first robot
« Reply #4 on: June 16, 2007, 12:11:08 PM »
Looks really clean to be your first.  I would say you have alot of potential.
Offline sotu
  • ïBB - Eye Biped Bot
Re: My first robot
« Reply #5 on: June 24, 2007, 07:19:18 AM »
Nice robot.. ;D Looks really cool!
You can buy a inexpensive microcontroller for 20$ at Pololu.com
How much did your cost? Couse i dont think you get a Computer program in the packcage at Pololu, thats the problem, HOW TO MAKE THE CODES AND TRANSFER THEM!!
How to build a biped bot:
Re: My first robot
« Reply #6 on: June 24, 2007, 11:06:53 AM »
my microcontroller was free :). Go to the microchip samples website and register on it. You are allowed 2 orders of up to 12 chips each a month. They also do serial eeproms etc. Its a great source of chips :)
As for a computer program, i just used GVim, a text editor, and wrote the program in assembly. I used a velleman K8048 to flash the PICs.
Offline NOOBinDistress
Re: My first robot
« Reply #7 on: August 30, 2007, 07:18:12 AM »
meybe someday ill finish a halfway decent robt ;D
Re: My first robot
« Reply #8 on: August 30, 2007, 08:14:14 AM »
Did you have to modulate the two IR sensors. I mean did you modulate the two IR sensors to two different frequencies.
 Also, if you would have one more IR in front it would be a lot more reliable setup.
Can you please tell us about the IR sensors. Schematics please...
Nice job man!
,Eric
Re: My first robot
« Reply #9 on: September 03, 2007, 09:34:18 AM »
Nah i didn't modulate the IR sensors, they are both on all the time. I figured i didn't need to - if there is no object in front, then no light will be detected, not matter how many IR LEDs there was.
Yeah a front IR sensor would have been good, but it was just a quick little experiment. Now i have a much better PIC programming setup (i have an ICD2 and some PIC18F4525s) i might consider making the robot significantly more complex.
The schematic is really simple. The sensors are just phototransistors in a voltage divider, and the output voltage is fed into an ADC. Pic makes decisions based on these reading sends forward or reverse signals to either of the servos accordingly. I dont think it is worth making a schematic.
Thanks for the compliments guys :)
Harry
« Last Edit: September 03, 2007, 09:36:35 AM by hazzer123 »
Re: My first robot
« Reply #10 on: September 04, 2007, 08:16:27 PM »
What do you mean by ADC?
The A to D pin on the microcontroller. OR a seperate chip. If so, which chip was it?
looking forward to the code.
Re: My first robot
« Reply #11 on: September 05, 2007, 09:50:29 AM »
I meant the ADC on the PIC.
I don't have the code any more sorry :(.
It was in assembly and not commented anyway, so it wouldnt have been too useful.
Ill be making a V2 robot soon. I will first make it behave in the same way as V1 and post the code which will be C (compatible with MPLAB C18).
Harry
Offline goatfish
Re: My first robot
« Reply #13 on: March 09, 2008, 03:25:31 AM »
that things a tank
Last post February 08, 2007, 01:23:07 PM
by hgordon
Last post February 14, 2007, 11:09:24 AM
by annoyin_kid
Last post February 19, 2007, 08:04:33 PM
by ComputerGeek
Last post March 15, 2007, 02:04:34 AM
by Tsukubadaisei
