Author Topic: Locking mechanism  (Read 606 times)
Offline prashantTopic starter
Locking mechanism
« on: January 24, 2011, 11:14:46 AM »
Hi ,
 Can any anyone suggest a mechanism to lock two bots together while on the move and work as a unison and also to disengage as per will??
 No restriction on size !!!
« Last Edit: January 24, 2011, 11:16:15 AM by prashant »
Offline garrettg84
  • Helpful? 8
Re: Locking mechanism
« Reply #1 on: January 27, 2011, 01:00:29 PM »
make them large enough to have their own gravity (think planet sized) and then put huge rocket boosters on them to separate at will.
Just kidding. =) Have you looked at something as simple as a trailer hitch? Just get a ball and cuff and put a servo on the little flip piece to lock the ball in. Loop and hook? How about putting a large screw on the end of a motor shaft and a nut on the other robot? Electro magnets? Permanent magnets with an ejection piston?
What kind of hold strength do they need? Does a com bus need to be established over this physical link or will it communicate wirelessly all the time? Will they always be on flat terrain, will there be obstacles?
-garrett
Offline Fr0stAngel
  • [O_O] what??
« Reply #2 on: February 01, 2011, 12:33:42 AM »
you can use a servo that turns a twisted aluminum bracket into a slot of the other robot...
another one could be electromagnets,
then there are also this way that you can kind of build a housing for robot into the other robot, and first robot can reside inside the cavity and move out at the right point etc. ;D
'crazy' is the new hype! =)
Last post March 15, 2008, 03:36:29 PM
Last post December 22, 2008, 09:38:40 AM
by Gertlex
Last post February 01, 2010, 08:08:11 PM
by jessman275
Last post July 13, 2010, 07:05:03 AM
