Author Topic: AXON PWM duty cycle?  (Read 1351 times)
Offline mstachoTopic starter
  • Helpful? 10
« on: January 24, 2011, 11:28:46 AM »
Just out of curiosity, if I use one of the PWM channels on the axon, what's the duty cycle, in seconds?  I ask only because I may have to do some software PWM'ing and I don't want to mix duty cycles...
MIKE
Re: AXON PWM duty cycle?
« Reply #1 on: January 24, 2011, 11:36:05 AM »
Duty cycle is measure in percent of the PWM period not in time (seconds).
What device do you need to control with PWM?
What frequency or period do you require?
  • Helpful? 10
« Reply #2 on: January 24, 2011, 01:29:36 PM »
Sorry, I meant PWM period.  I calculate the duty cycle on my own as a percentage of the period as you say, but once I know what percentage I want (I evaluate it as a PD controller) I am now just multiplying by the maximum integer, which in my case is 255, which represents one full period for the 8-bit PWM.  I want to know what 255 corresponds to in seconds.
As for the device, it's just a bunch of DC motors.  I can't use servos because I need both position and force control, so it's PWM for me :-)
MIKE
« Reply #3 on: January 24, 2011, 01:38:38 PM »
You should use WebbotLib. My original Axon library is now obsolete.
http://webbot.org.uk/iPoint/37.page
You can set your period to be just about whatever you want, although resolution is limited to the 16 bit timers on a 16MHz processor.
  • Helpful? 111
« Reply #4 on: January 24, 2011, 01:47:15 PM »
Servo software PWM requires 16 bit timers - but general pwm motor control can be done in WebbotLib using 8 bit timers.
