Author Topic: Problems with FBoot  (Read 1142 times)
Offline waylon531Topic starter
Problems with FBoot
« on: January 30, 2011, 10:11:47 AM »
Whenever I try and use the FBOOT command to upload the program to the Axon, it says, "Cannot execute FBOOT." Does anyone know what the problem is? I tried running cmd as administrator and it didn't help. I am running Vista 32-bit.
« Last Edit: February 02, 2011, 09:14:30 PM by waylon531 »
Offline klims
Re: Problems with FBoot
« Reply #1 on: January 31, 2011, 05:42:38 PM »
I was having problems with FBOOT that were related to being too deep in sub folders(I think). As soon as I copied all the files to the desktop it worked a treat
Hope this helps.
  • Helpful? 172
« Reply #2 on: February 01, 2011, 09:14:20 AM »
I line with what klims said, follow the tutorial exactly, using the exact folders and file names I used. After you verify that it works, you can make your desired deviations/modifications. Let us know how it works out :)
« Reply #3 on: February 01, 2011, 03:45:56 PM »
I tried moving it to the desktop and it worked great. Thanks klims.
