Author Topic: Running a car amplifier off mains / high current power supply help.  (Read 2251 times)
Offline z.s.tar.gzTopic starter
  • Linux Guru
I have an amplifier that I'd like to hook up for some sweet bass. The amp works fine with a car battery supplying the power (its intended purpose) but I can't get enough current off a former-computer power supply to take care of the peaks. What would you recommend to remedy this? My initial thoughts are put some capacitors in but even then I may not be getting enough for a sustained sound.
Offline want2learn
Re: Running a car amplifier off mains / high current power supply help.
« Reply #1 on: February 04, 2011, 05:05:24 AM »
What's the amps rated power?
What's the power supply's rated power on the 12v line?
There's a couple of threads on rcgroups about parelelling pc power supplies but take care!!
Why do you want to run the car amp and not one intended for the mains supply?
Jim
The question that drives me hazy:
Am I, or the others crazy?
Offline garrettg84
  • Helpful? 8
  • Armchair Roboticist Extraordinaire
« Reply #2 on: February 04, 2011, 07:24:17 AM »
Depending on the amp draw of the amp/subs you will likely need something more like a car battery(or two or three) with a charger always hooked up. I know I had a system that would draw hundreds of amps when the bass really hit. Had a capacitor bank and with the draw I still went through a couple of 200amp alternators a year.
Yes, my highschool years were spent listening to BAD music and wasting stupid money.
-garrett
Offline want2learn
« Reply #3 on: February 04, 2011, 07:30:06 AM »
The power coming straight from most car battery chargers isn't regulated well enough.
Charging the battery(ies) overnight/when not in use would be a better solution.
Jim
  • Linux Guru
« Reply #4 on: February 04, 2011, 10:10:25 AM »
@want2learn
Lets say for all intents and purposes the amp is rated 100W peak and 50W rms.
The power supply is rated 8A but of course that's constant, not peak.
I could put a few in parallel but that means scrapping some perfectly good psu's.
I have no money for a proper one and already own a car amp.
@garretg84
My lack of money means I don't have a car battery lying around to use.
Believe me,  this system couldn't draw more than 15A if it tried.
That's why high schools were invented; punks have to be corralled somewhere. (I was no exception.)
« Reply #5 on: February 04, 2011, 12:31:47 PM »
If you add a large caps (10,000µF to 1F depending on the peaks) and a couple of small ones (like 100µF, 1µF and 10nF) for noise, you should get it to handle the peaks just fine.
Remember to use heavy and short wires.
Offline want2learn
« Reply #6 on: February 04, 2011, 04:11:08 PM »
In that case the maths is close enough, just don't run the amp at full whack all the time and remeber to allow adequate cooling of the amp and psu.
Thats fair enough, there's a lot of us in that boat!!!
Jim
  • Linux Guru
« Reply #7 on: February 04, 2011, 08:00:20 PM »
I can't run the amp at full power because my cheap speaker bottoms out so it's not a problem  :P
I'm also not worried about the amp overheating since it's rated for 600W and is a brick of aluminum but I may put some better heatsinks in the psu. (I honestly forgot about heat)
edit: I put a 10,000uF cap in and it helped by a noticeable amount. I can get about 10 more of these pretty cheap but my concern is this: if I put say 10 capacitors in parallel do they need balancing? I've read this and that but I can't dig up a definite answer.
« Last Edit: February 04, 2011, 08:28:30 PM by z.s.tar.gz »
« Reply #8 on: February 04, 2011, 09:24:08 PM »
Capacitors don't need any balancing (whatever you may have read), as long as they're connected together, they cannot be at different voltages, so they're self balancing you may say.
Add 1 or a few at a time, and keep an eye on the start up surge (and the punch in the low frequencies of course, no need to add more than needed to cure the lows).
A large capacitance looks like a short circuit to the power supply at start up - you may even need to add a soft start circuit.
Suitable PTC resistor(s) would do the trick. A power resistor that is shunted by a relay when the caps are up is another common solution.
Last post July 24, 2009, 01:51:28 PM
Last post August 13, 2009, 10:47:09 AM
Last post September 01, 2009, 08:04:09 AM
by Kerry
Last post February 19, 2010, 04:00:32 PM
by Webbot
