Author Topic: GUI bootloader issue, not all the port available  (Read 453 times)
Offline jgrizouTopic starter
« on: February 04, 2011, 12:03:32 PM »
Hello,
I just bought an AxonII, I try to use the GUI bootloader but the COM5 is not define in the possible choice. I am well receiving the data with HyperTerminal, using COM5, and all my USB port redirect to the COM5 which is, I think, the COM number used by the driver.
I will use the command line version, but if this change could be added to the bootloader GUI it will help. I suppose it is a minor change  :)
Thank you
Re: GUI bootloader issue, not all the port available
« Reply #1 on: February 04, 2011, 12:34:22 PM »
Humm, finaly the same problem happen with the manual bootloader! When I define COM5 -c5, it try to open the COM1. So I cannot load my program on the AxonII  :'(..
Does one of you have an idea to fix this problem?
Thank you
John
« Reply #2 on: February 04, 2011, 12:46:28 PM »
The problem is that the bootloader can only use COM 1-4.
But it has a simple solution.
go to control panel -> system -> device manager
select the Axon in Ports, right click, properties
Port Settings tab -> Advanced...
now select a free COM port and push OK
« Reply #3 on: February 04, 2011, 01:45:14 PM »
Perfect, it works well.
Thanks you
Last post November 08, 2008, 05:57:15 PM
by sdavis6736
Last post January 25, 2009, 10:10:22 AM
by mgargiullo
Last post September 05, 2010, 11:43:26 AM
Last post November 11, 2011, 11:41:23 PM
