Author Topic: Mounting wheels with small Toe-In angle.  (Read 2266 times)
Offline brijeshTopic starter
« on: June 15, 2007, 08:10:37 AM »
In RC cars a small toe-in angle between 0-3 degrees is used to increase straight line stability. How about using the same concept with differential steering robots, with 2 wheels and a caster?
Has anyone tried it?
Here is link which explains Toe, Camber and Caster angles of wheels.
http://www.ozebiz.com.au/racetech/theory/align.html
With a Toe-In angle there will be some scrubbing of the wheel and loss of power. Question is how much will it help in keeping the robot going straight with a diff-steering?
Brijesh
Offline ed1380
Re: Mounting wheels with small Toe-In angle.
« Reply #1 on: June 16, 2007, 02:40:48 PM »
well when the robot starts going backwards it turns into toe out.
Offline sotu
  • ïBB - Eye Biped Bot
« Reply #2 on: June 17, 2007, 06:16:27 AM »
Most of the RC car toys i have dismounted the stearing mechanism is driven by magnets. Just magnets turning + and - by power controlling what way its going to turn, i dont know if that got anything with this to do tho.. :P
How to build a biped bot:
« Reply #3 on: June 17, 2007, 10:27:38 AM »
ed1380,
mm...true, when it goes in reverse it becomes Toe-Out. Looks like I have to experiment a little to figure out if Toe-In has any positive effects.
sotu,
By RC cars I meant hobby grade RC cars. In hobby RC cars steering mechanism is well designed with lots of features for tuning.
Brijesh
Offline maverick monk
« Reply #4 on: June 17, 2007, 07:29:09 PM »
that dosent apply to high proformance rc cars, the onroads use toe in, toe out, and camber as a tuning aid to improve the handling. they steer with a hobby servo and have bellcrank or akerman (sp) steering. very complex. great learning tool for dampning and suspension geometry.
ok, toe in is worthless on a robot unless your going at 20+ mph ( hobby rc go between 20 to about 50 or 60 on average) and are racing on a track wear hundreths of a second matter.
edit, sry didnt read the last post
« Last Edit: June 17, 2007, 07:30:49 PM by maverick monk »
Last post January 27, 2009, 12:40:40 PM
by ArcMan
Last post July 18, 2010, 04:42:46 PM
Last post September 16, 2010, 03:02:12 AM
by Alfa_Zulu
Last post October 24, 2011, 03:58:02 PM
