Author Topic: newby C programming question  (Read 2445 times)
Offline BANETopic starter
  • E=roboticsC^2
Re: newby C programming question
« Reply #30 on: February 27, 2011, 05:36:45 PM »
more like just trying to get my my feet wet with functions :D   and i thought this would a good challenge
just to clarify: My code that i listed works perfectly, I just want to try to make an equivalent function.
I'll post some code shortly of my attempt
  • Helpful? 107
« Reply #31 on: February 27, 2011, 05:52:52 PM »
This thread seems to be careering over various topics. Please consider splitting into different threads - else hard for anyone to 'Search' on.
Now seems to be to do with 'Tank steering' and may not necessarily be anything to do with WebbotLib
  • E=roboticsC^2
« Reply #32 on: February 27, 2011, 05:54:08 PM »
ok, wrote something simple for starters.
int findarea(int x, int y);
blaahahahahh long code that works
some code that determines y_final and x_final
displayGoto(&LCD,0,3);
rprintf("area   %d",findarea(x_final,y_final));
//--------------functions----------------------------------
int findarea(int x, int y){
return x + y;}
this simple code works. now just to get something similar that does the mixing logic
  • E=roboticsC^2
« Reply #33 on: February 27, 2011, 06:02:45 PM »
more like just trying to get my my feet wet with functions    and i thought this would a good challenge
it can see your point webbot and will start another thread but it still kind of relates to newby C programming questions :D
  • E=roboticsC^2
« Reply #34 on: February 27, 2011, 08:26:23 PM »
never mind the "how to use functions question", i figured it out and got my code working; just had syntax errors :P
I have a another question which is relevant to post ;).  The "rprintf" function only prints integers.  But what if i want to print a float?  Is it possible to print decimal numbers to an LCD screen?
thnx
Offline KurtEck
  • Helpful? 12
« Reply #35 on: February 28, 2011, 09:53:33 AM »
My guess is that you can use the function: rprintfFloat, but I believe you will need to define
#define RPRINTF_FLOAT
before the rprintf.h file is included...
I don't think he put any support into the actual rprintf function itself to support floating point.  Personally I prefer to avoid floating point.   Instead I usually try to go to some fixed point version.  For example if I were working with displaying the current battery voltage in 10ths of a degree I would keep the value as an integer where for example the value 62 would refer to 6.2 volts.   If on my remote I wish to display this, I currently simply display it as 62 (different processor... and I was lazy), but if I wanted to display it as 6.2 I could probably do something like:
rprintf("%2d.%1d", volts/10, volts%10);
Just a thought...
Kurt
  • Helpful? 107
« Reply #36 on: February 28, 2011, 02:25:47 PM »
Correct
Not in the rprintf but the rprintfFloat uses floating point.
100% agree
  • E=roboticsC^2
« Reply #37 on: February 28, 2011, 04:44:33 PM »
thanks guys, i was displaying values in mV but thought it might be nice to displays decimals.
rprintf("%2d.%1d", degrees/100, degrees%100);on my LCD this displays "%2d.%1d" not values, however this
rprintf("%d.%d", degrees/100, degrees%100);displays the correct values.
Does rprintf not support conversion specifications? (at least i think its called that)
I also tried rprintffloat
warning: implicit declaration of function 'rprintfFloat'
I get this warning ^^^ when using the float and it displays a crazy amount of digits; any way to get rid of the warning?
  • Helpful? 107
« Reply #38 on: February 28, 2011, 06:44:19 PM »
To support the 'conversion specifics' then you need to add
#define RPRINTF_COMPLEX
at the top of C code that does the rprintf.
All these '#define's may sound complex but are used to include the most efficient version of rprintf for what you are trying to do,
Also note that you should probably use:
rprintf("%2d.%02d", degrees/100, degrees%100);
So that the stuff to the right of the decimal point has leading zeroes where necessary.
The 'implicit declaration of rprintfFloat' is either becasue you haven't done a #define RPRINTF_FLOAT at the top of your code or you aren't using it with two parameters.
Last post August 12, 2008, 05:32:34 PM
Last post September 28, 2010, 01:36:21 PM
by greywanderer012345
Last post November 16, 2011, 09:09:04 AM
by schoeby
Last post January 21, 2012, 10:15:14 AM
by Daddysharky
