Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
Open motors in the water are actually shorting out , IF they work there running at very very low efficiency.
so distilled water has no resistance so electronics can operate without fear of short circuit under distilled water.
regular tap water typically has enough resistance to mess with digital electronics but i would speculate something like a small DC motor would still operate with reasonable efficiency under tap water.
obviously salt water is at the other end of the spectrum. much more power would be lost due to the conductivity of the liquid.some sort of mechanical seal would be probably be needed to keep the motor dry if you were using it under salt water.
but electrical short circuit is not the only concern.if the motor body were full of water the armature would experience far more resistance, meaning the motor would be under more load, draw more current, and generally be less efficient.
on the other hand, water is more thermally conductive than air so a heavily loaded motor would cool down quicker meaning you could allow it to draw more current without damage.
i'm not sure where these 2 opposing factors would balance out... you would need to experiment.
but i see no reason why a DC motor could not operate un-sealed in a fresh water fish tank.the only question is if it would be more efficient (both in construction time and operating performance) for you to seal it.
Dunk thanks for your vote on submersing in water too. Is there a way to make some distilled water as my budget is low and the tank is large.
[...] break in motors in the water to round out the brushes but doesn't that build up oxidation inside?
Soeren, I have searched for waterproof small dc motors but haven't found any any ideas to improve my search?
Hi,Quote from: AtomHex on February 07, 2011, 10:55:09 AMOpen motors in the water are actually shorting out , IF they work there running at very very low efficiency.No they're not!Water has got a much higher resistance than the motor - some people break in their motors under water.That said, it would shorten their life some of course.Please don't present a (wrong) guess as if it was knowledge.
My guess is not wrong....electricity can short out in water, water is a conductor,
I just didn't express myself in such eloquent terms as you did,
and , " it would shorten their life some of course. " are your words and in my world loss of efficiency includes shorter than life expectancy of a device.
And this part " Please don't present a (wrong) guess as if it was knowledge." even wrong guesses are knowledge.
And holy crap what a bunch of WIND BAGS including myself....The guy asked " How can I seal a small dc motor for water?"
I can bear constructive criticism but like I said HOLY CRAP........
#define [i]term[/i] (A_TECHNICAL_TERM)
O and by the way, how do you cut/past and dissect every little word and sentence and then comment on each statement wrong or right...does anybody else find that as anal as I do or is it just me.
Quote from: dunk on February 07, 2011, 02:20:10 PMobviously salt water is at the other end of the spectrum. much more power would be lost due to the conductivity of the liquid.some sort of mechanical seal would be probably be needed to keep the motor dry if you were using it under salt water.As far as my measurements go and taking a random small motor of say 10 Ohm as an example, I see no indication that it would not run, as less than 1% of the power should be lost to the water.
[...] and back fill with hot (toliet bowl or similiar) wax.
Quote from: Soeren on February 07, 2011, 08:04:20 PMAs far as my measurements go and taking a random small motor of say 10 Ohm as an example, I see no indication that it would not run, as less than 1% of the power should be lost to the water.A wha??? Soeren, this is dead wrong. Average sea water static resistivity is about .2 Ohm * meters. So for the distance between motor contacts of about let's say .05m (5 cm) the resistance is 0.01 Ohms. Versus your 10 Ohm motor, who is going to win?
Salt water is VERY conductive,
I've seen massive robots taken down by a few drops of it in a leaky connector.
I'll do you one better. Cup of water from my saltwater fish tank. Probe surface area roughly what you would find exposed inside a small brushed motor. 12V across 2" conducts about 1 Amp of electricity.
who would have thought there was a market in selling sea water right?
I'm kind of curious if anyone has experience with exposed DC circuits in pool water (highly chlorinated) and how much that affects conductivity.
I don't have a pool handy to test in, but some of the kids in my robotics club will be doing a submersable soon and the main competition will be in a pool.
what i don't understand about these figures is that they don't take into account the surface area of the immersed probe.common sense would imply that more probe area would lead to lower resistance (or higher conductivity if you want to use the Siemens scale).
on the other hand,Soeren is usually correct if you catch him sober so i might just cave.
[...] which is 5.307S/m = 1.9 ohms/m at 25 Centigrade.
it still doesn't answer the query about the probe surface area though.
Quote from: Soeren on February 09, 2011, 05:48:59 PMI'll do you one better. Cup of water from my saltwater fish tank. Probe surface area roughly what you would find exposed inside a small brushed motor. 12V across 2" conducts about 1 Amp of electricity.I repeated the experiment in saltwater and moved the probes closer together. At about 1/4" distance in-between (getting to real distances between brushes in a motor), the reaction got violent and my 3A power supply went into CC mode and started dropping voltage. I admit I mis-understood resistivity, but I'm not wrong about DC motor in saltwater = big trouble. Not just "1% loss".
I'll do you one better. Cup of water from my saltwater fish tank. Probe surface area roughly what you would find exposed inside a small brushed motor. 12V across 2" conducts about 1 Amp of electricity. So using your favorite equation, V = IR, about 12 ohms of resistance.
So how exactly does this equate to only about 1% power from a 10 ohm motor? Have you actually ever dunked a motor in saltwater?
No, but since you always like to bring it up, it's pretty clear you have some sort of "non-America inferiority/jealously" complex. Kinda like a kid who's jealous he can't have something so instead he takes every chance to make fun of it as a way to cope. Also, I didn't say they were American made. I've personally seen UUVs from other countries fail as well. Or would you like a list of the countries so you can think up irrelevant jokes for them as well?
CRAP!!! I hit modify instead of quote.
Except for the "Probe surface area roughly what you would find exposed inside a small brushed motor" Experimenting is good, undisclosing important engineering parameters are not.
No, I would've thought that you knew me better by now, but I just like to yank your chain every now and then and this is the easy way I've learned... Don't get so mad, it builds character (and hopefully some thicker skin) Tongue
How large a percentage is illiterate in the US these days by the way?
but luckily you can still modify a modified.
As much as I respect you Soeren, I hope i'm not the first one to say this, but your 'tone' always seems to come off a bit offensive when you make jokes in this regard. I'll try harder to not read into it in the future, but maybe find something else to pick on me about? As an American, I hear cracks against us all the time, as you might imagine. It gets old.
Started by Admin Robot Videos
Started by Commanderbob Electronics
Started by magnetman12003 Electronics
Started by Soeren Electronics
