Author Topic: stepper motor driver, sparkfun  (Read 2147 times)
Offline AdminTopic starter
« on: June 15, 2007, 10:48:08 AM »
sparkfun came out with a really easy to control stepper motor driver for only $15:
http://www.sparkfun.com/commerce/product_info.php?products_id=8368#
Description: EasyDriver v3 is a simple to use stepper motor driver, compatible with anything that can output a digital 0 to 5V pulse. The EasyDriver requires a 7V to 30V supply to power the motor, and has an on board voltage regulator for the digital interface. Connect a 4-wire stepper motor and a microcontroller and you've got precision motor control!
Caution: Do not connect or disconnect a motor while the driver is energized. This will cause permanent damage to the A3967 IC.
Features:
    * A3967 driver configured for 8-microstep mode
    * Compatible with 4, 6, and 8 wire stepper motors
    * Adjustable current control from 150mA/phase to 750mA/phase
    * Power supply range from 7V to 30V. The higher the voltage, the higher the torque.
Offline pokey
Re: stepper motor driver, sparkfun
« Reply #1 on: June 23, 2007, 04:55:45 PM »
Solid! I recently bought a Dakota Robotics Step1 controller with motor. It was expensive, but does what it says on the tin, and is a good choice for a n00b like me. I'll get one of these new ones for my next project.
http://www.robotshop.ca/home/suppliers/dakota-robotics-en/dakota-step1-serial-stepper-motor-kit.html
Offline megaman935
« Reply #2 on: June 23, 2007, 05:42:15 PM »
Noob question-
What is it used for and what does it do? :D
Offline megaman935
« Reply #4 on: June 23, 2007, 06:26:38 PM »
kool! :)
Last post March 15, 2008, 06:30:14 PM
by vivek9856
Last post October 06, 2008, 04:24:36 PM
by javafiend
Last post July 04, 2010, 07:37:46 PM
Last post September 29, 2011, 11:00:19 AM
by Fr0stAngel
