Author Topic: STK500  (Read 2239 times)
Offline bakilTopic starter
STK500
« on: June 15, 2007, 04:17:22 PM »
hy i recently got a STK500 kit and i then i tried to compile my c code (from tutorial) with avrstudio (gcc or something that makes c files standard) and then i just got stuck how would this come
(or just give me an other c compiler that works)
Offline rgcustodio
Re: STK500
« Reply #1 on: June 15, 2007, 04:49:25 PM »
What errors did you get?
I'm not sure if AVRStudio includes a compiler by default. You might need to install WinAVR (it is a gcc derivative, http://winavr.sourceforge.net/) then set AVRStudio to use WinAVR. WinAVR integrates very well with AVRStudio.
Re: STK500
« Reply #2 on: June 16, 2007, 02:05:18 AM »
ok how do u set avr studio to use winavr
Offline rgcustodio
Re: STK500
« Reply #3 on: June 16, 2007, 08:49:23 AM »
You mush have both AVRStudio and WinAVR installed.
Create a new project, Project -> Project Wizard, on the next window click on "New Project", then on the next window click "AVR GCC" under the Project type. This tells AVRStudio that your project uses a C compiler.
If you are already working on a project file (ie it was previously created) get the project's Project Options (Project -> Configuration Options). Goto "Custom Options" check on the "Use WinAVR" check box in External Tools if its not checked.
Hope this helps you out a bit.
Re: STK500
« Reply #4 on: June 16, 2007, 05:28:18 PM »
