Author Topic: 5V regulator... wich pin does what ? re 50$ robot  (Read 1224 times)
Offline rabadswompeTopic starter
« on: February 13, 2011, 10:45:15 AM »
With the "metal tab" resting on the table and the migddle pin being Ground... what are the left and right ones ?
Is it
Input-Grnd-5v output
or
5v output-grnd-input
edit- found this in an instructable... see attached picture.
I think I mixed up Webbot and Iadmin's wiring... I mean I soldered in the 5v regul Admin's way but constructed the whole circuit Webbot's way (as per the pdf diagram) where the 5v regul seems "backwards.
Soooo... I guess That's the problem I'm getting and that , while tab is flat on table, the pins really are 9v in-grnd-5v out
Can anyone confirm?
« Last Edit: February 13, 2011, 10:56:45 AM by rabadswompe »
  • Helpful? 84
Re: 5V regulator... wich pin does what ? re 50$ robot
« Reply #1 on: February 13, 2011, 11:44:07 AM »
If the regulator is an LM7805 then yes from left to right is: In-Gnd-Out
Google works very well for finding data sheets to parts so you can verify pin-outs etc.
  • Helpful? 107
« Reply #2 on: February 13, 2011, 12:38:56 PM »
Moral of the story is to follow one design or another. Don't assume that two different designs are based on each other  :)
Know that you are thinking of starting again - in which case you may find my tutorial here http://www.societyofrobots.com/member_tutorials/node/193 to be useful. Its for a different PCB design but the steps are still valid. Aplogies that is splattered in strange <!-- tags - wrote it in Word and uploaded it !
The essence of the tutorial is not to rush stuff. Keep measuring, checking at every step.
« Reply #3 on: February 13, 2011, 05:18:39 PM »
Thanks Webbot... I'll go read it and plow on!
If the saying "if your not making mistakes, then you're not trying" is valid...well, I'm trying real hard ;D
Edit: I understand things better now. My frustration came not from the design and its originator(s) but fro my inability to correct myself. Thanks for the link to your tutorial Webbot! I've learned!
« Last Edit: February 13, 2011, 08:01:06 PM by rabadswompe »
Offline dmclifton
« Reply #4 on: February 14, 2011, 05:56:47 AM »
Is it
or
Can anyone confirm?
Yeah, I also noticed that the pdf has the regulator backward from how Admin has it in his layout, but there is no statement to that effect. I left a comment about this on the bottom of the thread.
« Reply #5 on: February 14, 2011, 09:33:27 AM »
Webbot gave me a good lesson! Again, many thanks!!!!!!!
It is soooo wrong to assume that Admin's design and Webbot's are identical...they are not. Go with one or the other ...you can't go between. I thought Webbot's was easier to read for me (I know little about electronics).
I flipped the 5v regulator so that the plastic(black) side faces the capacitor (again, like in Webbot's pdf ). I also had a small short at the MOSI pin of the ISP. (easy fix)
Once these 2 things were done, I turned on the juice, connected the ISP, uploaded the hold_servo.hex and VOILA... servos were spinning .
I'm a happy camper again!
« Last Edit: February 14, 2011, 09:35:05 AM by rabadswompe »
« Reply #6 on: February 17, 2011, 09:30:50 PM »
[...] uploaded the hold_servo.hex and VOILA... servos were spinning .
Doesn't sound much like a "voilà moment" to me  ;)
Last post September 17, 2010, 01:30:44 PM
by Metal Slug 2
Last post March 14, 2009, 04:08:37 AM
by superchiku
Last post October 03, 2009, 03:29:02 PM
by madsci1016
Last post September 17, 2010, 10:01:46 AM
by GearMotion
