Author Topic: Ohm's Law for Idiots  (Read 2322 times)
Offline _Moonbot_Topic starter
  • It's...in...It's in...the box. IN THE BOX DOFUS!
« on: February 16, 2011, 10:31:26 AM »
I'm new to robotics and was wondering if someone could explain Ohm's Law to me.   ???
The claw...
Offline blackbeard
Re: Ohm's Law for Idiots
« Reply #1 on: February 16, 2011, 10:53:14 AM »
ohms law basicly shows the relation between resistance, current and voltage. look at the wheel below
Uploaded with ImageShack.us
instead of E you can use V for voltage. by shifting arround a the ohms law calculation you can find current, voltage and resistance using any of the other 2 variables. If for instance you have a 1.5v battery with an unknown resistor.
you measure 0.00075 amps. with that info you could find out what the resistor is through the ohms law calculation R=E/I or R=1.5/0.00075. the answer is 2000 meaning you have a 2k resistor!
Next step: Give them vaginas
Offline newInRobotics
  • Helpful? 46
  • N.I.R.
« Reply #2 on: February 16, 2011, 11:09:35 AM »
Ok, I hope You know Google, try pressing the link  ;D
Once I've read a nice explanation of Current, Voltage and Resistance is. It goes something along these lines.
If You compare electricity to Your house water system:
Voltage is a Water Pipe
Current is a Water Flow
Resistance is a Valve(or a tap)
Now, You can imagine that the bigger the Water Pipe the bigger Water Flow is.
Same with electricity, the bigger the Voltage, the more Current You can get.
If You have a Valve(or a tap) You can reduce Water Flow with it because size of the Water Pipe is reduced at that spot (if You get what I mean), hence with Resistance (Resistor) you can reduce Current by creating a Voltage drop at a certain spot in a circuit.
That's what Ohm's Law is about.
I - Current
V - Voltage
R - Resistance
I = V / R
V = I * R
R = V / I
There is a nice free simulation software called Yenka that has loads of useful and interactive examples on basic electronics.
Take care  :)
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #3 on: February 16, 2011, 12:47:11 PM »
That's not entirely accurate... The voltage drop is the consequence not the form factor... Resistance is the form factor... Or even better applied voltage at a closed circuit is the form factor...
Ohm's law says that the current is analogue to voltage applied in a close circuit of certain resistance... ;-)
That's more obvious if you know about non lineal components like diodes where there is always a voltage drop added to ohmic voltage drop...
Anyways, I'm just saying! That color example was a very nice writing!!! Keep it up mate ;-)
Cheers!
  • Helpful? 46
  • N.I.R.
« Reply #4 on: February 16, 2011, 01:03:24 PM »
Yes , You are correct, voltage drop is a consequence of by resistance reduced current; I've expressed myself that way to make it easier to understand the basic concept.  ;)
Take care  :)
Offline Ricfy
« Reply #5 on: March 04, 2011, 03:28:48 AM »
Hi all,
Anybody know how to convert the LDR OHM NSL 5520 the candela?
Ohm's Law
Started by rockrobotics « 1 2 » Electronics
Last post March 13, 2010, 01:22:08 PM
by rockrobotics
Last post November 20, 2011, 12:02:58 AM
by bens
