Author Topic: Super noob multimeter question  (Read 1698 times)
Offline ribsTopic starter
« on: June 16, 2007, 04:32:54 PM »
Hi, I just got all my various robot parts in the mail and am getting ready to start on the $50 robot.
I turned on my very first multimeter for the very first time, and tested the voltage meter on a battery and the resistance on a resistor.  Yay.  First analog reading ever.
I'm reading the manual for the multimeter for measuring current and I don't get it: it says not to apply a voltage across the leads when measuring current.  Then it says to break the electrical path where I want to read the current, apply the leads, and turn on the power.  Doesn't inserting the meter into the circuit and turning on the power apply voltage across the leads?
Thanks for the help.
Coming soon: my first solder ever ;)
Offline ed1380
Re: Super noob multimeter question
« Reply #1 on: June 16, 2007, 05:01:04 PM »
when measuring voltage touch one lead on the ground (-) and the other on the power (+)
for current you have to do this
« Reply #2 on: June 16, 2007, 06:03:52 PM »
Ok, I get it.  Break the circuit and insert the leads of the multimeter where I broke the circuit.  The manual is telling me not to span a resistor or something in an unbroken circuit because it could damage the meter, but it is redundant, assuming I have followed the directions of breaking the circuit and applying the leads correctly, right?
Thanks!
Offline ed1380
« Reply #3 on: June 16, 2007, 06:17:40 PM »
right. make the current go through the MultiMeter to check the current
Last post October 26, 2006, 02:27:59 PM
by polar bear6
Last post May 31, 2007, 05:37:37 PM
by TravelingPencil
Last post August 01, 2010, 04:03:06 PM
by random robots
Last post August 12, 2010, 09:35:15 PM
by tmoney68
