Author Topic: [Solved] How do you tell amps drawn by motor?  (Read 512 times)
Offline RedcapTopic starter
  • Helpful? 11
« on: February 17, 2011, 09:05:28 PM »
Hey all.
I've been doing a little research into what I need to control DC motors from an Arduino.
At this stage I'm looking at a SN754410 MD chip (instead of buying a motor shield).
I'm planning to run two hobby motors off it, I'm not sure of the motor specs (not even sure when or where I got them).
As such, how can you tell how many amps a motor is drawing?
(I know the SN754410 can handle 1amp per driver.)
Thanks in advance,
Redcap
« Last Edit: February 17, 2011, 09:41:23 PM by Redcap »
  • Helpful? 84
Re: How do you tell amps drawn by motor?
« Reply #1 on: February 17, 2011, 09:15:06 PM »
Well the Stall Current is close to what is calculated with Ohm's Law and a measurement of the DC resistance of the motor winding. This would be the maximum current the motor will draw and a good rule of thumb for sizing the driver.
The no load current can be measured by putting a low value resistor is series with the motor and battery. Measure the voltage drop across the resistor and calculate the current with Ohm's law. Chose a resistor value to get around 0.1 to 0.3 Volt drop.
  • Helpful? 11
« Reply #2 on: February 17, 2011, 09:41:00 PM »
Ah, much thanks Waltr :)
I knew it had to do with Ohm's law, but wasn't sure how to implement it as such :)
Cheers :)
Last post August 28, 2008, 06:21:26 PM
by TrickyNekro
Last post September 02, 2009, 07:12:14 PM
by Hawaii00000
Last post December 19, 2010, 04:08:36 PM
by madsci1016
Last post January 07, 2013, 08:23:01 PM
by jwatte
