Author Topic: alert !!  (Read 926 times)
Offline shyamgeniousTopic starter
  • TECHNO GEEKS AND SCIENTISTS ROCK BUT DO YOU??
alert !!
« on: February 18, 2011, 04:01:42 AM »
dear admin
plz take care to read this without getting bored ;D :-X
i am a beginner and have made a robot only outta crap.
i am planning to make a robot which can go through all terrain,land,water,air.
i live in india and my suppliers are very low so i am just asking a query that i which board should i buy of these two-     http://thinklabs.in/shop/product_info.php?cPath=25&products_id=79 .or http://thinklabs.in/shop/product_info.php?cPath=25&products_id=78.your .the dollar 50 robo is somewhat useful but could you suggest me some parts?? oh i forgot to tell that i also wish to install the following-
1.a gas releaser
2.a microphone and camera
3.a device which allows it to connect with my laptop AND control it
4.all should be waterproof
5.it should be able to shoot a missile capable of penetrating thick surfaces and inject liquid
6.it should be able to disguise it self as common items like a coke can or soft drink bottle
7.should run on four wheels
8.should have retractable wheels
9.should have a propeller behind<for water of course>
10.should be buoyant so that it can float in water
11.it should have wings and should be able to fly
12last but not the least it should be lightweight so that it can perform its functions correctly
plz guide me so as how to make this robot
-awaiting your reply
shyamgenious
« Last Edit: February 18, 2011, 04:14:02 AM by shyamgenious »
The wise only need a hint to know whats going on.The fools cannot understand even if its given in writing.You decide-
 which are you?
regards,
ShyamGenious
Offline Kelpy
Re: alert !!
« Reply #1 on: February 18, 2011, 11:04:17 AM »
That sounds very ambitious :o
Offline nickc
Re: alert !!
« Reply #2 on: February 18, 2011, 02:44:58 PM »
the iboard.
you forgot to add it should make you coffee in the morning.  ;)
Re: alert !!
« Reply #3 on: February 18, 2011, 09:48:44 PM »
y not the prostick?? is it not the same as i board??
the iboard.
 which are you?
regards,
ShyamGenious
Re: alert !!
« Reply #4 on: February 18, 2011, 09:51:11 PM »
cant ANYONE take up the challenge?? i thought the robot making would be easier with sor helpining me!!!! so sad
 which are you?
regards,
ShyamGenious
Offline BANE
  • E=roboticsC^2
Re: alert !!
« Reply #5 on: February 19, 2011, 08:44:19 AM »
dear shyamgenious,
I want to build a time machine like the one from back to the future.  I dont have any money or knowledge of such things.  all i have is a pizza box, a toaster, and a used condom. plllllzzzz help!
catch my drift?  ;)
this might sound simple and easy to make after watching a science fiction movie but this is really complex!
if you are serious about building something close to your description youll need to take it one step at a time
so for the the quote above ^^^ it would be in your best interest to hack an RC toy like this one http://www.hooked-on-rc-airplanes.com/rc-flying-boat.html
then you might use a Axon II for its new brains and upgrade prop motor for a bigger payload.
Once you have the Axon II you can then add a bluetooth module to use your laptop as a controller as well as add a mic and camera.
1.a gas releaser
ls
you might want to try what i recommended trying first before attempting the above :P   However, even if you get a robot that is land,water,air it still would be awesome!!!!
« Last Edit: February 19, 2011, 08:48:07 AM by BANE »
Offline Fr0stAngel
  • [O_O] what??
Re: alert !!
« Reply #6 on: February 19, 2011, 02:45:51 PM »
well we all get excited when we think of making a robot and plan big etc.....don't we?
but shyamgenious, all the things you mentioned cannot be done at once....take it one step at a time.
start by building a land robot (has less complications) ....once you start it, you'll find its not that easy, since there are constraints on money, time and knowledge.
but, don't give up...keep on learning new things and in the meanwhile keep working on your robot...
once done with that , you can move on to modify it to a marine or air robot too.
i don't want to demoralize you or anything, but please go one small step at a time, otherwise , you may lose interest in your new 'interest'..
Good Luck..! :)
'crazy' is the new hype! =)
Re: alert !!
« Reply #7 on: February 19, 2011, 10:15:20 PM »
[...] all i have is a pizza box, a toaster, and a used condom. plllllzzzz help!
You need to be a bit more selective the next time you dive a dumpster!
(And remember to wash the latter carefully before reusing, or at least turn it inside out  :P)
Re: alert !!
« Reply #8 on: February 20, 2011, 02:30:11 AM »
thanks for those so enlightening comments but ive already started building and am stuck as to how to lift it in the air
propellors or those like in copters??plz sum1 help
 which are you?
regards,
ShyamGenious
Offline rbtying
  • Helpful? 31
Re: alert !!
« Reply #9 on: February 20, 2011, 02:35:43 AM »
Since you seem to be building this out of arbitrarily selected materials, I'll tell you now that the only thing likely to lift your robot off the ground would be a number of model rocket motors, or possibly 2+ brushless ducted fans.
Re: alert !!
« Reply #10 on: February 20, 2011, 08:38:55 AM »
Sorry to burst your bubble, but the Transformers were just movie special effects.
Last post March 16, 2011, 08:17:16 AM
by Fr0stAngel
